![]() | Home > Td5 > Disco 15p Td5 into 10p Defender |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
I'm not sure about the NNN000120 ecu, but the NNN500020 is fully programmable for defender files. That's what I've used in the past.
Just trying to find a spare one can be difficult! You may have to jiggle around with the fuel pipes/fuel cooler system to get the 15p engine to fit. |
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 ![]() ![]() ![]() |
Thanks - I’ll do some digging on the fuel pipes issue.
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Could you not ask one of the tuning companies to solder in a programmable chip? Maybe easier than sourcing another ecu etc.
Every day’s a school day! Didn’t realise you could do that. It certainly sounds easier. Any idea who to look at? I’ll do some googling on the way home. Thanks.
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 665 ![]() ![]() ![]() |
There is a small difference between 10P and 15P engines - the temperature and pressure sensor in air box are different (different connector, more wires in 15P). The rest should be the same.
Also Defender engine is missing the wastegate modulator. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Thanks MadTom - what does that mean in installation terms? Swap over the sensors from 10p to 15p?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5988 ![]() ![]() ![]() |
Is a simpler approach just to swap over the injectors in the the newer engine, use the old loom and plug in and keep the same ECU & use the same turbo or is there more to it than that? 1999 Defender TD5 110
I don't think it's just the injectors that are programmed differently in the 10p vs 15p ecu. I think the map is different. But I'm no expert.
Keeping the same 10p ECU and 10P injectors would be a start? 1999 Defender TD5 110
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1781 ![]() ![]() ![]() |
Can't put 10P injectors in a 15P head. Something to do with the fuel channel design being internal vs external and the pressures involved.
It is not possible to use 10P Injectors in 15P engine, and opposite.
ECU - to test that engine runs, you can use any ECU, you need just to pair the IMO (learn security code with nanocom). For proper use and run, use the right ECU with the right map and code injectors. Sensor in filterbox - not just simple change - 15P sensor has different size = different hole to filter box, and different connector. Nothing hard to modify, just some work. For 15P engine you need 15P sensor. 10P sensor is just filterbox air pressure, 15P is also air temperature. For proper work of engine (first step before any upgrades) you need proper sensor. Without it, engine will run, but with some limitations. There is also another difference - 15P has different EGR valve - with exhaust gas cooler and 2 vacuum controlled flaps. And also some small differences in cooling water pipes - look into RAVE for details. For future tuning (remap) 15P engine is better, because the software (maps) has more lines and columns and can be better upgraded. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Bone question but can you plug the 15p loom into the sensor in the air box if it is a 10p sensor? Reason I ask is that I replaced the airbox on mine with a second hand one just after I got it because one of the catches was broken & never even thought there might be a difference in sensors - plug fits no problems so I am hoping all is good!?
Thanks MadTom - is the wiring already in the 10p loom for the 15p sensor? How do you physically connect the dual function sensor if you're changing from 10p to 15p? |
rciii Member Since: 11 Apr 2019 Location: Aveiro Posts: 1 ![]() ![]() |
Hi all,
I'm doing the same operation of swapping my 10p by a 15p on my Defender. About the Airfilter sensor, do I need also a new wiring loom? Wat about the acelerator. It should be 3 way now, rigth? Do I need to change anything on the wiring loom here? I don't have any EGR. I guess I can keep the original coolant pipes About the fuel pipes, do I need to change anything? Thanks in advance you for your help |
