Home > Technical > oddssey battery help
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
how can you check that a battery is in good condition its a pc1500 with no vents to check water levels
i aquired it at the weekend from work as it was only bought in oct 2010
and been replaced i drop tested it before leaving work with it and it came up with needs charging
any help appretiated
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #71201 16th May 2011 8:31pm
leeds
Steve, the Odyssey 1500 is an AGM battery. i.e. it is an Absorbed glass mat battery without any free electrolyte so there is no way of topping it up.
Just charge it with a decent charger such as a Ctek charger set to AGM setting (snowflake)
HTH
Btrendan
Post #71207 16th May 2011 8:48pm
big steve
ok well iv charged it i suppose the only over way is to put on a car or landy and try it ?
Post #71210 16th May 2011 8:57pm
BigMike
Do something heavy with it ie a load of winching and really give it a hard time then recharge again. If you dont do that with odysseys they just dont last. Great for heavy work, terrible for just standard battery fare.
Post #71219 16th May 2011 9:38pm
leeds
Are you confusing Odysseys with another battery starting with an O, Mike?
We use Odysseys as standard batteries in our Disco with no problems. Odysseys have a goor reputation.
Brendan
Post #71223 16th May 2011 9:46pm
BigMike
Nope. For anything except heavy load/discharge/load etc, Odysseys are overkill (in my opinion) when there are others like varta etc which will do the job just as well for less than half the price.
Post #71224 16th May 2011 9:51pm
big steve
ill try working it hard 2015 2.2 tdci hardtop xs
Post #71228 16th May 2011 10:05pm
BigMike
I did mean Optima, sorry bren (and steve) Laughing
Post #71244 16th May 2011 11:28pm
big steve
Went and had it tested properly today at a battery specialist
It's absolutely fine result really as I got it for nothing Laughing
Regards steve 2015 2.2 tdci hardtop xs
Post #71547 18th May 2011 6:49pm
