|  | Home > Technical > Puma 2.2 Clutchfix |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500      | Yes get the kit from Ashcroft! 2008 110 2.4 XS Utility (Hagrid)
 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold | ||
|  13th May 2018 6:03pm |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | Definitely while it's all apart. Recently had a clutchfux kit fitted to mine and took the opportunity to fit an ashcroft output kit at the same time    | ||
|  13th May 2018 7:46pm |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946      | The Clutchfix is on my list when mine goes next.
 I've read mixed views on the Ashcroft transfer shaft (the one that leaks to lubricate). I get the impression the Standard one is fine if well lubricated when installed. Definitely, check it's condition when the clutch is out. Be interested to hear how you like the Clutchfix. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers | ||
|  13th May 2018 8:07pm |
| Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025      | How did you find the pedal with the Clutchfix kit Hank? Much stiffer? | ||
|  13th May 2018 8:09pm |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | No difference whatsoever, same as standard to operate. I went for the 'uprated' master cylinder as well, not sure if that makes a difference | ||
|  14th May 2018 8:54am |
| Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025      | Bit of an update, clutch fitted & a happy Puma! Had to adjust the master cylinder arm & bleed it backwards but yes...vast improvement. | ||
|  22nd May 2018 6:23pm |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584    | Glad you like the clutch and the service.  We try to keep them in stock so they can be with a customer within a couple of working days, courier God’s willing.
 Brendan | ||
|  22nd May 2018 6:56pm |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720      |
 The Ashcroft shaft is just the standard shaft with a groove eroded into it so it leaks oil, then a collar over it to keep the oil from being lost. Effectively the Ashcroft kit just ensures the standard shaft is kept well lubricated, you can smother the standard shaft with the Land Rover approved grease as per the official TSB, but they still fail as the grease gradually gets flung out. Some people have had several standard shafts. | ||
|  22nd May 2018 7:50pm |
| Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589      | One cannot access the shaft/spline for service.
 Some drill even holes in order to access the shaft inside the housing This is one of the biggest mistakes JLR ever made... | ||
|  11th Jun 2018 8:50pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      |
 Any idea what spec is the LR grease for this splines? Thanks Puma 110" SW ............................................................. Earth first. Other planets later | ||
|  12th Jun 2018 11:54am |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946      | I asked this exact question yesterday on FB, but not had a definitive reply.
 There are kits available that have everything you need, including "special spline grease" for example https://lofclutches.com/shop/tdci/tdci-out...cba1185463 James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers | ||
|  12th Jun 2018 1:31pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | IIRC it is Weicon anti-seize paste that JLR specifies, which seems an odd choice. A good quality molybdenum disulphide grease, with the highest moly content you can find, would seem a more logical choice, but one has to assume that JLR knows what it is is doing (although the fact that JLR designed the problem in the first place suggests otherwise)!
 Moly grease is generally specified where surfaces rub (litiium where they roll), hence it is used in CV joints, motorcycle shaft drives, etc. | ||
|  12th Jun 2018 3:13pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | I´m becoming a bit paranoic about the shaft failing. I have covered 87kkm only though. I have some slack on the transmission but I´m blaming the central diff tufnol shims. Puma 110" SW
|  15th Jun 2018 12:38pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | If it is any comfort, the 2007 model year seems generally to have longer-lasting shafts than subsequent years. My '07 at time of writing is on the original shaft, greased at 150k miles and currently at 225k miles.
 I realise that it is tempting fate to say this, of course. and by doing so it will probably now fail. | ||
|  15th Jun 2018 1:52pm |
| Posting Rules
