Home > Puma (Tdci) > Puma TDCi 2.4 2010 - Puff of smoke on slight throttle change
Puma2010doo
Puma TDCi 2.4 2010 - Puff of black smoke on slight throttle change or brief throttle lift-off at motorway speeds (UK 70mph)
There is no smoke from the exhaust under startup or heavy acceleration.
Post #711696 10th Jun 2018 11:06am
defendergram
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Buckingham Blue
I had exactly the same issue earlier in the year, although mine flagged an engine warning light at the same time. It turned out to be a failed mass air flow sensor. A cheap-ish and very simple fix on the driveway, hopefully someone can advise if it could be the same?
Post #711771 10th Jun 2018 7:41pm
dgardel
Italy
Yes could be the faulty MAF or a near to stuck EGR valve Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #711947 11th Jun 2018 8:18pm
