Home > Maintenance & Modifications > Help removing pop rivets from air con grille
Zed
What is the safest idiotproof method for removing the pop rivets that attach the aircon grille?
I'm worried I will damage the surround with my drill. Is there another way or technique?
Post #711452 8th Jun 2018 6:07pm
bankz5152
Drill them out.
Post #711458 8th Jun 2018 6:46pm
Realistically, a drill is the only option. When I did mine recently, I found that the edges of the rivets did take some of the paint off, unfortunately. Darren
Post #711459 8th Jun 2018 6:47pm
Support them properly, drift the broken setting stem out of the back of the rivet, then drill out the centre hole.
Post #711467 8th Jun 2018 7:16pm
Mwd
I cut the projecting stems off the rivets on the inside of the grille with a Dremel and cutting disc as close to the plastic as possible and then just pushed the remains of the rivet outwards. I did scratch the plastic in a couple of places but it’s on the inside and is invisible when the grille is in position. I was worried that i’d crack the plastic if I tried drilling them out and was really pleased with how well the Dremel worked.
Post #711509 8th Jun 2018 9:46pm
zsd-puma
Drill them out and replace with dome head stainless bolts. They'll cover over where the rivets were.
Post #711520 8th Jun 2018 10:34pm
Zed
Thanks for the replies chaps. Pretty much as I thought. Guess it's just my lack of confidence but I'll just have to man up and get on with it.
What's the worst that could happen...
Post #711528 9th Jun 2018 12:06am
bankz5152
Yep. Youre drilling out a few pop rivits you can barely see unless you look. Dril them out, dont be a panzy Smile
Post #711531 9th Jun 2018 1:10am
LR90XS2011
drilled mine from the front,, no visible damage as the new screws cover the rivet area DEFENDER 90 TDCI XS,
Post #711533 9th Jun 2018 5:38am
discomog
Drilling them out is the easiest option and as said above, replace with machine screws and nuts.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #711536 9th Jun 2018 6:11am
Zed
Cheers Discomog. I bought the fixings you kindly recommended on another thread. (M5 x 16 Torx pan head setscrews) What size drill bit should I use?
Post #711537 9th Jun 2018 6:41am
I used black nylon nuts and pan head bolts on mine as it's a non-loadbearing fixing. Purely for cosmetic reasons.
 Darren
Post #711548 9th Jun 2018 8:55am
discomog
Sorry Zed, forgot what size drill bit. I seem to recall that it was about 1mm less than the diameter of the pop rivet head. If you take it steady you'll find that the head will come loose or just start to spin. Stop at that point, lift off the head then push the rest of the rivet through. If you have a pop rivet gun then put a couple of pop rivets in a piece of scrap and practise if you're not sure. It's relatively easy, you'll just need to bite the bullet and man up Rolling with laughter Defender 90XS SW
Morgan Plus 8
Post #711550 9th Jun 2018 9:00am
Zed
Cheers mate. I'll put my big boy pants on and give it a go.
Post #711602 9th Jun 2018 4:25pm
NickMc
Just use a good quality sharp drill bit, sharp is the key!
Post #711623 9th Jun 2018 6:27pm
