![]() | Home > Maintenance & Modifications > Dinitrol or galvanize chassis? |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
If your chassis is that bad go to LR dealer & ask about claiming on the corrosion warranty - you have a 2016 Defender so should still be covered.
If they don't sort it then I would personally go with a new galv chassis on the basis that if it is rusting that badly externally what will it be like inside the box sections? As for cost, I'd budget about £5k if you get it done at a suitable garage or specialist - supply & fit plus doing various replacements whilst it's apart, brake pipes, etc. |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
Should probably add that Land Rover refuse to cover any part of the chassis as part of the corrosion warranty, they are not even covering the back of the crossmember. I've been fighting with them for ages now, I've given up.
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
That’s poor. I think quite a few folk have had the rear crossmember tarted up under warranty. Can you try a different dealership?
Not the dealership, LR themselves say it's just cosmetic. Besides the point, if they approve the work they will only tart it up. I want to preserve the entire chassis.
Where I'm struggling though is why people keep suggesting I buy a new one. The current one isn't great but it's not that bad yet. It's well within saving. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
![]() A galvanised chassis will basically last for ever. If you have the money and space/time to do it then it's worth doing in the long run. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
have you any photos? DEFENDER 90 TDCI XS,
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
If a galv chassis is within your scope, then why not leave it until it's really bad and then do a chassis swap? I was just reading on Zagato Corrosion thread he even recommends dinitrolling a galv chassis. Would be easy to do on a nice new clean chassis, might be worth it.
Shocking to hear it's that bad already and JLR won't do anything! Was I was researching getting mine undersealed I read a comment from someone saying don't bother spending £500 every 3-5 years sealing just wait till its bad and replace with galv chassis. Good luck James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
That's probably because it'd make it a much easier task to do. To have your existing chassis galvanised would require the vehicle stripping down and then storing all of those parts somewhere whilst the chassis was sent off to be treated. You would be without the vehicle for weeks rather than a few days to swap it onto a new chassis. If you've got the space and facilities to strip and store the rest of the vehicle then saving the existing chassis would probably be cheaper, but if it needs repairing first then that may become marginal. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 ![]() ![]() ![]() |
Go galvanize.
I did it by taking my 110 oop north and leaving it with Paul Marsden who's 50 yds from richards chassis - 2 weeks later complete chassis swap done for cost of the richards chassis plus £1500. thoroughly recommend both richard and paul marsden 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
Been talking to people and I think a new galvanized chassis is the way to go. As I will be replacing anyway I don't really need to worry about the current chassis yet for another while. If I was planning on saving it then yes, I'd be in a hurry but replacing.... I can' take it easy for another couple of years. I'll just tart up visible bits for the time being.
It wouldn't hurt to buy a cheap can of waxoyl and a garden sprayer and blow around on the chassis, especially in side the chassis rails. Even a quick bodge job will give you a year or two more out of it, ie. cut down on the amount of patching and welding you do.
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1487 ![]() ![]() ![]() |
Dan,
I'm quite shocked to read that you're considering changing a chassis that can only be 3 years old at most. It makes me think I need to give mine a good check over just to be sure. It was waxoyled 3 years ago, when a few months old. If it ever does need replacing, I will wait until it is absolutely necessary. I don't see the point in spending upwards of £5000 on it now, in case it might need it later. A lot could happen in the meantime, and you may never get to see the benefit of a galvanised chassis. Until then a regular top up with waxoyle or dinitrol will help it last a bit longer. |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 ![]() ![]() ![]() |
How has it got so bad in only 2-3 years? Launching boats? Or farm work? Even the utility company Defenders you see that rarely get washed only have surface rust at 8-10 years old.
How does the rest of the underside look? Bulkhead, axles etc? They may all need a clean and coat of paint too. |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232 ![]() ![]() |
I would power wash it down on a sunny day. Wire brush any loose rust off. Buy some aerosol tins of CIO from BUZZWELD and treat everything you can. If you do it yourself you know it's done right plus it will only cost materials. CIO drys so quick the LR will hardly be out of action. When the time comes to weld any part of the chassis treat yourself to a new one. Future proof the vehicle by Galvanising everything steel you can. |
