Home > Technical > Boost Leak?
hank
Boost Leak?
Perhaps it's my paranoia but recently the turbo hiss seems to be louder than I had previously noticed. The hiss is emanating from the passenger footwell kind of area on turbo spool up.
Any known issues? Tricks of the trade to test for leaks? Having someone rev the engine while stationary doesn't seem to spool up the turbo?
I have not noticed any other symptoms to speak of such as power loss, erratic idle etc
Post #711205 7th Jun 2018 9:37am
mk1collector
You don’t have an allisport intercooler do you? Ray
My build thread
Post #711210 7th Jun 2018 10:19am
adeparko
Scotland 2007 Defender 90 Td5 HT Sumatra Black
Check around the intercooler hoses for a split in the rubber
Post #711214 7th Jun 2018 10:27am
hank
No alisport intercooler.
How do I check, soapy water?
Post #711216 7th Jun 2018 10:30am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Not sure if you are TD5 or TDCi but we had a lot of problems with intercooler pipes and intercoolers splitting on a fleet of TDCis. The latter used to separate between the plastic end tank and the main core.
Sopay water works well for finding leaks Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #711225 7th Jun 2018 11:09am
hank
2.4 TDCi
Ok so I need to get under the bonnet with a sprayer then and douse the pressure side of the inlet. Will report back
Post #711232 7th Jun 2018 12:02pm
rallysteve
Also worth checking that no rubber grommets have been dislodged in the footwell resulting in more noise being apparent. Not sure on TDCi bulkheads but the rubber grommet in the passenger footwell for the A/C pipes can let a lot of noise through if dislodged.
Post #711236 7th Jun 2018 12:27pm
bankz5152
Rolling Eyes Rolling Eyes
Check boost on diagnosticsor boost gauge. Should be roughly 14psi if it hasnt been messed with.
Check if any of your boost hoses have oil residue around them anywhere. If so clean them up and check after a few drives
Post #711238 7th Jun 2018 1:13pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I had a similar problem on my Td5 last year, it was making an increasingly loud hiss from the front while giving it full beans, especially uphill.
I suspected either intercooler or hoses but there was nothing visually obvious and since it was only hissing while driving, I decided the best way to diagnose it while stationary was to pressurise the intake system.
I removed the pipe from air filter box to the turbo inlet and found a plastic pot which was a snug fit over the turbo inlet, I drilled a hole in the bottom of the pot and fitted an air hose fitting which I was able to connect to my compressor and apply about 15PSI.
Lo and behold it was the intercooler which had split along one of its seams, it was partly hidden from view by the air-con condenser but immediately obvious where the noise was coming from.
A quick visit to a friend of mine who's a dab hand with aluminium welding and it's good as new. Thumbs Up
Post #711288 7th Jun 2018 7:17pm
adeparko
If you floor it going up a hill, do you get lots of black smoke out the exhaust?
This would also usually point to a split hose
Post #711290 7th Jun 2018 7:20pm
mk1collector
What make intercooler is it Clive? Ray
My build thread
Post #711311 7th Jun 2018 8:58pm
mk1collector
Sorry, forgot I’m not allowed an opinion on a product I bought Rolling Eyes Rolling Eyes Ray
My build thread
Post #711314 7th Jun 2018 8:59pm
bankz5152
Of course. Though you seem to slag em off anytime you can as if they where Britpart!
Like I said dude look for oil residue around the IC or hoses, bit tell tale of a boost leak.
Post #711326 7th Jun 2018 9:25pm
Clive
I couldn't say to be honest, it was on the 90 when I bought it 3 years ago, the only clue might be that it was re-mapped by td5alive.com, now known as Alivetuning.com. maybe they supplied Alisport ones back then - or maybe not?
Post #711331 7th Jun 2018 9:32pm
mk1collector
I’ve received better quality parts from britpart in the past than the part I bought from allisport so what do you expect? Ray
My build thread
Post #711348 7th Jun 2018 9:52pm
