![]() | Home > Maintenance & Modifications > Bulkhead grommet. Madman Install. |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
If you’re double jointed yes
I have a set of mole poles and pull the wires through with it. |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
Ive sent a couple of wires through there. Easiest way was to get some stiff steel wire and push it through from the engine side. With the centre console and instrument cluster out you should be able to see your wire, wiggle/grasp it and pull it through into the cabin. You can then attach the wire you want to send back the other way and pull it through. I think it helped a lot if you can get someone else to assist so you have one person on each side. 2007 110 TDCi Station Wagon XS
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
It's probably just as easy to take the dash out. It's not as difficult as it looks.
The one on the passenger side is a bit easier to access from inside if feeding cables along the inside of the bulkhead is viable. |
| 2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562
Yep, I’ve had the dash out a lot, good shout going into the passenger grommett instead,
was looking at that instead, less cables going in there as well. Thanks |
| All times are GMT |
