![]() | Home > Td5 > TD5 Clutch Pedal Mod |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I'm suprised that you Td5 people actually need to fit these springs... my (factory) 300Tdi from 1996 had one as standard, and then my Td5 110 (2001) also had it.
Pretty much every other clutch pedal box (Td5 era) i've seen for same has had one fitted. unless there was a batch that never did? |
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
We're talking about Land Rover here
True... probably a pallet load of mid 80's pedals they had to use up
| Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384
Ive had a good look at my pedal and its not got the mod.
You must have followed some good owners. |
I did the clutch pedal mod yesterday, bit of a fiddley buggar to do, but christ, what an improvement!
Well worth doing, makes the action alot lighter. I had to undo the bolt securing the pedal to the master cylinder to get the spring in place, not a hard job just very fiddley, took me around an hour. The parts were 45 from Britpart, the little U shaped plastic bush was 19, what a rip off! |
| Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567
Ive fitted this mod what a diference didnt do it like the mag (taking the bonnet off etc) just fitted it from the drivers footwell and used a pair of sniped nosed mole grips the fit the spring took 10 min
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| elpeede Member Since: 09 Jun 2011 Location: Staffordshire Posts: 1 |
The pedal in my 1990 110 (not a td5 but TD) is also stiff. Is this article specific to the TD5 only. I note the picture on the first page covers from 1986.
If you look at the drawing i posted on the other page, you are looking for a u shaped cut out on the pedal stem and a bracket behind this with two hols on either side to place the bushes on, if you have these i guess its a goer. Doubt any major mods have been done on these parts. |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803
I'm going to do this mod. Has anyone got the part numbers and details for the accelarator pedal mod too as I find this also has a lot of resistance. Andy
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
There are no parts required for throttle pedal mod. It is just a case of drill hole, and relocating spring into it.
Andy |
Thanks, think I need to order the back issue of LRO, unless any kind sould woul be able to scan and mail it to me? (the instruction page that is) Andy
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I did the modification to the clutch pedal on my 110 today, although it wasn't the easy but fiddly task that some have found. No amount of pushing, twisting, forcing and cursing could get the new spring into place. In the end, I resorted to disconnecting the clutch pedal from the master cylinder, after which it popped into place quite easily. Disconnecting the pedal took minutes and if I'd done that from the outset, I'd have saved myself a lot of time and frustration
Still, done now and the difference is incredible. It's much more driveable, particularly in traffic, and saves my old knee from a lot of grief 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106
Just ordered the parts there now, God I only found this website the otherday and many of the niggly little things that annoy me in my defender-the cures are posted here
Thanks for this thread as the extremely heavy clutch on my current TD5 drives herself mad on a long journey Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
