![]() | Home > Off Topic > Ctek Charger/conditioner - Not impressed |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
Because a Ctek charger is not a battery tester.
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
The charger is working as intended. It only reports an error if the voltage after steps 1-4 drops to 12v. You clearly had more volts than this so no error reported. It might be worth trying to recharge the battery in Recond mode before buying a new battery. |
Leave the charger connected and momentarily switch the headlights on or the starter.
Check the charger report afterwards. ![]() |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Put the charger in recon mode over night, it will bring your battery up to better than new! Then use the maintenance function
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
