![]() | Home > Td5 > Starting Problems TD5. |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 ![]() ![]() ![]() |
Hi Folks,
I've gone through changing a few of the obvious. I've changed the Injector Loom, the Injector Seals and rings, and also the fuel filter valve. When I put the key in the ignition and turn it i can hear the fuel pump. The starter keeps turning the motor over but it sometimes will and sometimes wont start. It was taking longer and longer to start even if the engine was warm. Now it barely starts after trying until i killed the battery. I've charged up the battery and after a few times it started.. so I drove it around and i turned off the engine on a hill. I tried turning it over and again it wouldn't start. However, everytime I bump start it, it starts immediately. I've spent so much money trying to problem solve it. I'm convinced its the Starter motor, can it be anything else? |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Have you changed crank position sensor? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
I was thinking it could be that too. Any thoughts?
Very good possibility bud I had that before not cheap but if it starts on pull spot on I’d say a fair bet 2008 110 2.4 XS Utility (Hagrid)
I would check the loom again, I replaced mine and within a month oil was creeping into the electrical contacts on injectors 3/4/5 cleaning these out it would start fine and run for a week or so. I have now gone to town on sealing another new loom and so far it’s all good. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Put a load on the starter motor and see instead of throwing parts at it and changing the variables.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Check your crank sensor. It is located on the passenger side of the flywheel housing. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
How is he going to check it? Why would he need to change it? what are the symptoms that tell you that?
Take your startermotor out and clean the contacts and the small gearbox it has. I did mine last year also because starting became slow. The grease in the gearbox was almost solid and I hardly could turn the motor by hand. Clened it and put grease in there and it starts now quicker then when I bought it in 2009. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
My starter turns the motor. I changed the crank position sensor yesterday and no luck. It still doesnt work. How difficult is it to get at the starter motor without hoisting the vehicle?
Very easy, no issue at all. Just lay under it to undo the pos wire(s) and to get at the bottom bolts. The top 15mm is the PITA. You’ll need a couple different length extensions to get to it and you’ll only be able to turn is a 1/4 turn at a time. Remove the engine sound cover to make it easy.
Good luck ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
