Home > Technical > Anyone use the 100 quid Brit part wheel spacers ?
razz
2001 Defender 90 Td5 PU Caledonian Blue
Afternoon everyone , I wanting some 30mm wheel spacers , cos my 265 tyres are catching on full lock with the standard alloys , any one use the Brit part cheapies ? My local has some for 250 quid , sod that , might as well buy new wheels at that cost , anyways , your thoughts if any , bare in mind , mine only comes out to go round a pit or to be mot’d
Tar
Post #710133 31st May 2018 12:22pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Why don’t you adjust the turning Cycle? Is even cheaper!
But seriously i wouldn’t use cheap parts on my axle. If it was my choice non Or proper ones. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710137 31st May 2018 12:56pm
Knowing Britpart they'll probably be square instead of round. Rolling with laughter Avoid imo. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #710140 31st May 2018 1:35pm
razz
I hear what you saying , I use britpart throughout as it only does rough stuff and breaking cheap is ok by me , think i’ll do some good old eBay searching Thumbs Up
Post #710146 31st May 2018 2:05pm
razz
Terrafirma look ok , and have good reviews , so does that raptor 4x4 stuff , big choice out there
Post #710148 31st May 2018 2:10pm
The thought of using a Britpart wheel spacer sends shivers down my spine.
The only way that that they can be sold cheaply is if they are made cheaply, and that either means cheaper raw materials, cheaper tooling, cheaper staff, or cheaper quality assurance, or any combination of the above. Would you want your life to depend on a part made in that way?
Post #710150 31st May 2018 2:14pm
hank
adjust the steering stops, your tyres will no longer foul Thumbs Up
Post #710152 31st May 2018 2:25pm
dorsetsmith
more to follow
fond it
Post #710157 31st May 2018 2:51pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Totally agree with Blackwolf to the extent that I use -10 offset wheels rather than use spacers - even quality ones!
Years ago I used an adapter to fit the car spare to the caravan after a puncture - watching the wheel complete with adapter overtake the car put me off spacers for life Neutral
Post #710161 31st May 2018 3:03pm
dorsetsmith
me no, thing in blue boxes Evil or Very Mad
Post #710162 31st May 2018 3:05pm
zsd-puma
as above adjust your lock stops.
I would think with 30mm spacers and 265 tyres you'd also need wider wheel arch spats?
Post #710166 31st May 2018 3:12pm
razz
Cor , awesome reply’s , thank you . And thank you dorsetsmith for looking up the lock stops , I do like the steering I have when using steels , so , once I get it rebuilt , i’ll treat it to some new steels on zero off set , to give it the wide look I like , in the mean time , i’ll Set my lock stops cos that’s a doddle . Thanks everyone Thumbs Up
Post #710168 31st May 2018 3:18pm
That's quite a common combination and still fits under standard spats. Does spray muck up the sides, though. Darren
Post #710179 31st May 2018 4:09pm
In fact if you run 285/75 KM2 muds on Boosts with 30mm spacers they still -just!- fit under the arches, although you'd better like dirt all over the vehicle (inside, too, if you open the windows). For a while I ran this combination, then I saw the light. Rolling with laughter
Post #710185 31st May 2018 5:00pm
Litch
265/75x16 was a factory fit option on Defenders for may years and they never needed spacers, just set up the steering-stops correctly (as already suggested several times on here!) and all will be fine. ONE LIFE, GET IT!
Post #710231 31st May 2018 8:31pm
