Home > Puma (Tdci) > front crank seal
Cruiser100
front crank seal
Any special tools, advice for changing this?
Post #710062 30th May 2018 11:25pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
No, straightforward job.
Your new seal will come with an insert which helps you push the new one on,
Don’t take it off before you fit it, a gentle anti-clockwise tap with a punch will release the old one,
Then slide the new one on, tap around to lock it, job done Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #710078 31st May 2018 7:20am
Siwynne
Is this an oil out job or can it be done without dropping the oil. Reason I ask is mine is in under warranty having this done and oil service came on day before going in. If they have to drop the oil then it’s a free oil change for me.
Post #710091 31st May 2018 9:41am
ian series 1
No need to drain the oil, it’s quite a way up past the level. Thumbs Up 80" 80" 86" 88" 90"
Post #710092 31st May 2018 9:54am
Siwynne
Ah well another opie order coming soon then.
Post #710107 31st May 2018 12:03pm
zsd-puma
Question
Post #710114 31st May 2018 12:19pm
Siwynne
I’ll order oils from opie as I always do for all my vehicles to ensure correct low SAPS oil is going in for the right price.
Book stamped by local indie for warranty purposes.
Save a £600 ish service bill for a B sevice!
Post #710123 31st May 2018 12:44pm
