Home > Puma (Tdci) > Random Steering vibrations
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi, I recently rotated my tires and have been experiencing random difficult to control steering vibrations. The entire steering column vibrates. When I apply the brakes to slow down the vibration subsides almost immediately. It reoccurs only when I manuvere the steering over an uneven road.. Any idea whats causing this?
Post #709804 29th May 2018 7:37pm
Arsath
Here is a video of the same experienced by someone else.
Post #709807 29th May 2018 7:58pm
dorsetsmith
1. Wheels balanced and swapped round
2.Kingpins checked for play
3.Wheel bearings checked
4.Pan hard bushes
the swivel housings bearing pre-load that has to be set with a spring balance. It is adjusted by shimming the kingpin bearing. If the kingpin bearings have got a little worn, this could definitely cause the symptoms that you are experiencing i.e. death wabble
Post #709809 29th May 2018 8:07pm
NickMc
You shouldn’t rotate tyres on a Defender not good practice unless you do it regularly and in the correct direction for your tread pattern. Suggest you try putting them back Thumbs Up
Post #709812 29th May 2018 8:27pm
