Home > Camping, Caravanning and Holidays > Defender 110 Camping Trip - loading advice please?
chrislines
Planning on upgrading our Ford C-Max to a 110 Defender for family camping trips and adventures.
With 4 passengers, our plan is to fill the back with camping gear and also utilise a roof rack for extra storage. Couple of questions:
1. Interested in peoples experience (photos?) of how much gear they actually got into a 110. How cautious do you have to be re over loading??!!
2. Any advice on carrying 4 bikes as well - roof rack or?
I was trying to avoid getting a trailer for the C-Max and am hoping a 110 will do the job!
Thanks! Chris
Post #709720 29th May 2018 12:36pm
Stacey007
Hello
I've had fairly big estate cars (e class merc) 2 x ML's and both for trips have a roof boxes . They are nowhere near as boxy as the 110. I do quite like to keep a small window gap so I can see though the middle but it does not always work. Especially coming back from france with an additional 40 bottle of wine Smile
The 110 swallows everything, not pretty I want to make some shelfs... but I even have the 7th seats in the back. No roof box. If I didn't have the seats (the kids like using them once there) it would have acres of room Smile
Tents, chairs, coffee machine, beds, everything just goes in we used to Caravan so take a LOT of stuiff!!, I already had this bike rack so bought an extension bar and it fits great. Very stable. Driven thousands of miles like this.
Post #709721 29th May 2018 12:47pm
donmacn
Just as above. We had a C-Max, and a 110 - at the same time, so familiar with both.
For the 110 - we had camping trips, with 4 bikes. Quite a bulky tent, and all the paraphernalia younger kids seem to need. It takes this no bother at all. I've had the RIB (boat) attached to the back, two canoes on top. No worries. (When not towing, the bikes go on a maxxrak - attached behind the towball).
For a normal, family camping holiday, if you need more kit than a 110 can carry - you're carrying too much!
As for overloading - I doubt you'd get near the car's limits. My old thing doesn't have anti-roll bars, so if it was loaded like this, I can feel it lean a bit more, but nothing to worry about. On a more modern vehicle, I doubt you'd even feel that. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #709727 29th May 2018 1:22pm
chrislines
Thanks so much Stacey007. Very encouraging and great pics!! Yes long trips to French Alps etc with equipment and two kids is what we need to do.
Is that a standard Thule tow bar carrier then - 4 bikes?
Post #709732 29th May 2018 1:52pm
chrislines
Thanks donmacn. You're talking about an external roll bar cage/kit are you? Even without you think still nothing to worry about if packing in like above photos?
Haven't purchased 110 yet but does stability vary with age then? Might need to consider this if so...
Post #709735 29th May 2018 1:57pm
Thon
These photos show our 110, fully loaded in the rear load space (to the roof), plus 2 roofboxes and 3 Zarges cases. Suspension is 100% standard (including anti-roll bars) and as you can see in the 1st photo, is only slightly lower than when unladen.
The roof is likely fairly overloaded even though it was used for transporting lightweight items but in mitigation our rack is also supported on the roll cage. C of G is noticeably higher and you need to be mindful with sudden direction changes, but this is common sense. This was taken before setting off from Venice via Cortina over the Dolomites and onwards to the Brenner Pass that night. I drove appropriately to the conditions and vehicle and at no point was concerned about the loading.
I would have preferred to use a trailer but ours wasn't secure enough for our belongings for overnight hotel stops.
I would not advise putting bicycles on the roof unless you really can't fit them on a rear rack. They create a lot of drag.
Post #709739 29th May 2018 2:15pm
Stacey007
Hello
Mines been to Annecy a few times now, 550 miles in one day. The Thule rack is on a boom bar ro extend it out further than the wheel,
It's around £120 but I already had the rack from previous cars and its a great bit of kit so not bac rather than change the rack.
Mine in Annecy at Holiday house (Parents may I add,..)
Post #709740 29th May 2018 2:17pm
JOW240725
These are underneath as part of the suspension to reduce roll, nothing to do with roll cages. All the latest station wagons have them but some commercials didn't have them, depends what you're getting? They can easily be added or indeed uprated.
As for camping 110 are ideal. We carry a huge amount and if very carefully packed can get it all in the back and a roof box. We have the rear two seats which reduces space by a huge amount. If you don't need them I'd go for a Utility or just take the rear seats out to give the most room.
We found the roof box was quite difficult to load, being so high, so found a trailer to keep everything in. It just makes everything easy to access and most stuff is stored in the trailer so little packing, just hitch up and go.
We've now picked up a rooftop tent and the red Defender has no rear seat so it swallows everything and makes an amazing camping vehicle. Eventually, the RTT will be put on the trailer.
Good luck with your purchase. Have you ever driven a Defender? Whilst we on here all love them, they are quite unique, in many ways and not for the faint hearted Shocked Confused James
Instagram @suffolk_rovers
Post #709751 29th May 2018 3:21pm
chrislines
Thanks for all the comments and great pictures! You are a friendly bunch!
I had no idea about the anti-roll suspension. Was there a year this came in? Good it can be added. Even without it though on an older model, still safe though presumably for loading up?
I have driven a 110 and loved it! I think I'll be looking at a late nineties, early 2000 one price wise.
Post #709765 29th May 2018 4:42pm
chrislines
Stacey007 wrote:
Hello
Thanks for this info!
Post #709766 29th May 2018 4:45pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
if I may just add a couple of quick comments that you may have already considered ...
put the heavy items in as low as possible as that will help the CofG,
and secure the load so as it wont move should there be an incident and become a projectile.
we put things into must haves and nice to haves, then load them in that order. Soft bags take up less space than boxes, and if you can buy it there why take it with you ...
Defenders are robust all their lives, and if well maintained should not change their handling characteristics very much over time. - just keep an eye on the bushes and suspension.
enjoy the trip!! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #709771 29th May 2018 5:18pm
donmacn
I can't precisely answer the question about when they came in. I don't think it was necessarily a year, more a vehicle spec. issue. For example, my car is a 1994 SW but it was a 'utility' version, and began life as a working vehicle at an island airport. No anti-roll bars.
My mate had a 1993 Station wagon, in a higher "County" spec. His had anti-roll bars.
As you say they can be added. I've considered it - just never reached a conclusion! They can be had pretty cheaply on ebay.
"Still safe for loading up without them?" Absolutely. My comments further up the thread are based on this 1994 110 SW with no ARB. I've had it pretty heavily loaded with no issues at all.
As has been said, if I'm diving, with tanks, weight belts, compressor etc etc, then as has been mentioned above I will pack so that the heavy stuff is low down. If I'm travelling solo, then I'll sometimes put heavy stuff in the front footwell, or rear footwell, so that it's sitting between the axles - but I know I don't really have to do that.
I also spend most of my time (Nth Scotland) on relatively twisty A, B or C class roads. I don't (and wouldn't) have the slightest concern about not having ARBs.
All of that said, I bought an old RR classic once. Never driven one before. Took it for a spin on some very windy road. I wasn't ready for the body roll. That was properly scary. However, once you learn how it all works, and you keep it well maintained, you can hustle these things along quite reasonably.
Enjoy the trip!
 Donald
in the past..
Post #709789 29th May 2018 6:33pm
Four bikes on the roof is perfectly doable but they are a long way up. When I did it, I carried one of those 'hop-up' steps to be able to reach.
 Darren
Post #709829 29th May 2018 9:20pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
We regularly camp taking two adults, two kids, two medium sized dogs and four bikes.
Our format is:
Rear Seats removed, dog guard fitted.
Bikes on the roof - keeps them out of the way, away from prying hands and easy to get the dogs in and out the back. Getting them on and off is just a case of hanging bike on the roof rack cage by handle bar and seat and rest pedal on window.
Wooden shelf across the wheel arches with tent(s) and deck chairs/table underneath. This means you can get the tent out first on arrival and last in when packing up.
All our kit is then all in boxes and bags and packed to the roof on the right side of the rear. All strapped in place using dog guard, luggage hoops and grab handles. This takes just over half the floor space.
The remaining floor space is for the dogs.
If we have more stuff we have put a layer of boxes under the dogs.
Sorry no pictures of the load space but you can just make out through the window on this photo:
Post #709849 29th May 2018 10:07pm
Martin 01
Our 110 loaded up on most trips with either camping gear or tintent.
Roof tent on top with roof box for extra storage of lighter gear.
Sometimes have couple of large Ortlieb strapped on roof to.
Also have the Trasharoo spare wheel bag that swallows plenty of gear.
Rear consists of dog crate, fridge, chairs, beds & bags of clothing.
Usually full to the rafters with the 4 of us, 2adults + 2kids aged 14&10.
Post #710061 30th May 2018 11:23pm
