Home > Technical > Problems removing rear A Frame Ball Joint
Glyn D
Hi all, I posted a while back when I was about to buy my first Defender.
I went ahead and bought it, it's a 1996 300tdi Defender 90 and have tinkered with it almost every day since. Today's job is the rear A Frame ball joint but it's proving to be a bit difficult.
I've manage to free up most of the bolts with a big hammer. The problem I'm having now is that the ball joint thread is turning whilst I'm trying to undo the 30mm nut which secures it to the axle.
Any suggestions how to stop the ball joint from turning so that I can remove the nut?
Post #709312 26th May 2018 3:37pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
You'll be replacing the nut with new so you can just cut it with a grinder or split it with a chisel.
Chris
Post #709314 26th May 2018 4:13pm
Glyn D
Thanks Chris, I asked the same question on another forum and found a different solution which worked for me:
https://www.landyzone.co.uk/land-rover/pro...nt.331214/
Post #709317 26th May 2018 4:28pm
