Home > Off Topic > Oil fired cooker
walfy
Oil fired cooker
So with a possible house move imminent, we need to look at cookers. The current tenant is taking the current cooker with him. It's a single stand alone unit and not that clean so not really bothered.
Looking at replacing it with an electric range cooker or an oil fired cooker.
The heating is oil fired currently as there is no gas into the property.
So to those that run an oil fired cooker all year are there any benefits over an electric? Or are there any downsides? Is it a sensible option for all year? Does it produce to much heat in summer? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #709285 26th May 2018 12:09pm
nick345345
Scotland 2012 Defender 110 Puma 2.2 USW Baltic Blue
Hi there, I've got an oil aga, it's the only cooking appliance I have, no microwave, kettle, toaster. Run it all year round. It can be a bit warm in the summer, but then I live in Scotland so not too much of a problem Smile Also it's nearly 50 years old, and despite running just fine it could probably do with re-insulating which would stop it giving off so much heat.
Mine has a back boiler so apart from really cold days of the year I don't need the heating on. Aga is enough to heat the water and keep the kitchen warm. Log burner does the lounge.
Probably need to factor in servicing it twice yearly to keep it running well. Last couple of years I've been doing it myself, and I'm no technician. Once you work out what ropes and wick you need, and the general principles it's simple enough. Plenty of help on the web. And be prepared to get a bit messy when doing it...
Having had an aga for 6 years I can't imagine not having one now. It's not the cheapest think in the world to run, but worth it for me.
Post #709291 26th May 2018 12:51pm
gilarion
Another suggestion would be to buy a Calor Gas cooker and a couple of 47Kg Calor bottles, simple pipework to outside.
Electric AGA's are eye-watering expensive a single oven circa £2,500 double oven circa £3.500-£4.500.
Whereas a Calor Cooker top of the range will set you back about £250.00
Two large Calor bottles will last all year even longer depending on how much you cook. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #709295 26th May 2018 2:08pm
jst
depends really on the budget to buy. i wouldnt have an electric style aga which i think is what you are eluding to?
calor gas bottle cooker is good suggestion.
i have oil fired aga, run it all year, service it myself once a year, it does my hot water too, uses 4-6L a day, we use that and log fires through the winter to keep house warm.
benefits, you always have somewhere to dry stuff, it cooks much better, you never forget to preheat the oven, kitchen and rooms above are nice and warm, keeps residual property temp up.
downside it uses oil daily! servicing is quite straight fwd.
Also worth looking at the on demand oil nozzel cooker, their name escapes me currently. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #709307 26th May 2018 3:45pm
walfy
Many thanks for the advice, electric aga is not on the cards currently, heard they are horrendously expensive to run.
We are down to an electric range cooker or oil fired aga.
Cost is a consideration but not a determining factor 110 D250 SE HT
110 USW SOLD
Post #709319 26th May 2018 5:35pm
jst
you can pick up oil fired Agas none refurbished for £250 in some papers if your not in a rush! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #709357 26th May 2018 8:54pm
Pilgrimmick
I run an old Reyburn on oil. It has a wick and therefore does not need electric to power the blower, just something to think about if power cuts are likely to be an issue. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #709359 26th May 2018 8:59pm
walfy
Thats good to know. Thumbs Up Move is looking like July at the earliest 110 D250 SE HT
110 USW SOLD
Post #709373 26th May 2018 9:52pm
Chopperone
We run a Stanley oil fired “Aga” & an electric hot plate & oven.
Stanley gets turned off in the Summer & we use an electric immersion for water.
IF I was starting from scratch I would go calor gas either off 47kg cylinders ( we use these for our cabins/kitchens on site) & we pay about 20 quid a cylinder delivered OR a Calor tank.
Agas & hot summers really don’t go together in my experience
Guy May your life be like toilet paper ; long & useful.
Post #709390 27th May 2018 8:22am
Toby60
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
We also run a oil Aga but we turn it off in the summer because it gets too hot in the kitchen and use an electric cooker and hob. The Aga is also expensive to run but at least in the winter it heats the room as well as cooking.
I would favour the Calor Gas cooker and hob as it’s cheap to install and economical to run compared to oil. I would run this from 2 x 19kg Calor cylinders on an automatic changeover valve, ie it runs on 1 cylinder and changes over to the other one when empty allowing you plenty of time to get a refill. One 19kg cylinder would probably last for a couple on months. ------------------------------------------------
2002 TD5 90 HT County
Post #709404 27th May 2018 9:36am
Zed
Same here. We have an oil fired aga and have to turn it off in the summer or it gets much too hot but we also have an electric oven and separate hob so it's no problem. However I think we will put in a calor gas hob soon for wok cooking and also change our oil central heating for air source. Still trying to decide whether to keep the oil aga or swap for electric or wood.
Post #709407 27th May 2018 9:47am
We fitted An esse range,oil fired runs central heating, water and cooker, moved since but still miss it
Post #709413 27th May 2018 11:25am
jst
Esse, that's the one I was thinking of Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #709448 27th May 2018 5:05pm
BigRuss
We were looking at installing an oil fired aga but the more we looked into it the electic total control aga is a great option. Every oven and hot plate can be turned on individually, you can set it to slumber to give a gental radiant heat in winter and you also get a controller with it to turn the ovens on and off twice a day.
That teamed up with a wood burner allows for heating in the. Kitchen area and an additional cooking location should we lose power. Russell
2011MY 110 XS USW Black
Post #709481 27th May 2018 10:17pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
‘a genital radiant heat’
You can’t beat taters done on the Aga Laughing
Post #709483 27th May 2018 10:23pm
