Home > Technical > Defender td5 transmission oil
Page 2 of 2 <12
AJC
i put fresh MTF is mine not so long ago. No issues
Post #708551 22nd May 2018 7:41am
zsd-puma
MJN110 wrote:
Thank you ZSD Puma for educating me on this issue.
You would think then that somebody would be able to manufacture a shaft with tighter tolerances to partially eliminate this problem for sure it would be a good seller.
Ashcroft already do an upgraded adaptor shaft kit. The standard ones aren't too bad when new, the problem is they aren't properly lubricated so the splines fret, which means they get progressively more sloppy until they fail. The Ashcroft kit solves the lubrication issue.
Land Rover themselves also offer one piece rear half shafts that get rid of more slack in the drive train, but they're expensive and were only fitted as standard in about the last year of production.
Post #708600 22nd May 2018 2:20pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Thanks again ZSD-Puma for your information.
I tried the faster gear change 1st to second when cold and I had perfect gear changes so that problem is solved and I will stick with the MTF gear box oil. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #709075 25th May 2018 8:12am
ibexman
I use redline for the R380 copes much better with the heat when towing
Post #709076 25th May 2018 8:20am
MJN110
I will be towing on a regular basis fairly soon in what respect does the R380 cope better with redline? 2016 Defender Landmark 90
Post #709082 25th May 2018 8:43am
ibexman
It’s much smoother when cold I was quite surprised really I was looking for a better quality oil copes with heat well try it :
Have a read up Thumbs Up
Post #709083 25th May 2018 8:53am
MJN110
Do you mind telling me which Redline product you are using there seems to be 2 gearbox oils? 2016 Defender Landmark 90
Post #709087 25th May 2018 9:05am
ibexman
MTL not cheap but quality never is
Post #709093 25th May 2018 9:45am
Glad that trick works for you too! I still don't understand why it works, but it does.
As stated above I really don't rate the R380 at all highly, Landrover was never very good at gearboxes but the R380 was surely one of the worst. Ford on the other hand was always very good at gearboxes (especially in the '60s and '70s).
Post #709101 25th May 2018 11:06am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
What brand of mtf94 is everyone going for?
Post #709126 25th May 2018 12:34pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I went for genuine LR, not cheap but thought it may be worth going for. Have not used it yet so unable to comment on the performance.
Mike
Post #709132 25th May 2018 1:05pm
Page 2 of 2 <12
