Home > Td5 > Two new front calipers soft pedal
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
2000 MY Td5 with ABS and TC. I just replaced the two front brake calipers as the original ones each had a seized piston. Bled the system with new DOT 5. Started at rear far side, rear near side then front far side and finally front near side. Bled through a litre and a half of new fluid (that should have purged all the old DOT 4 that was in there. i reconnected the battery after bleeding and still cannot get a firm pedal (did all this twice). Big Cry
Any advice is welcome. (I have done this many times just never on a Wabco ABS equipped Defender). Am I missing something? Or do I just keep on bleeding it?
Let me know. Cheers Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #708082 19th May 2018 4:54pm
4RF RDS
Thansk for all the views and help... Not! Laughing RESULT: Brand new in box caliper was partially seized. 🤬 Had to rebuild a new caliper. Sad state of affairs when new parts can’t be trusted 😢 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #708320 21st May 2018 10:00am
NoDo$h
Did you use DOT5 or DOT5.1? I'm hoping 5.1.....
If you flushed through DOT4 with DOT5 you will have started a fairly aggressive reaction between the fluids in your brake system that leads to corrosion and the creation of solids in your lines and calipers. Unless filled with DOT5 from new, it's NOT recommended that you perform a swap.
DOT5.1 is compatible with DOT4 - however most decent DOT4 fluids have boiling points as high as, if not higher, than the min. spec for DOT5.1
A bit of googling found the following:
Quote:
"Silicone Brake Fluids
In years past, all brake fluids were glycol. Then D.O.T. 5, a silicone fluid having a higher temperature rating, emerged, initially to meet the higher boiling point requirements of racing use. (Race car brake systems include oil-cooler-like heat exchangers and ceramic pads.) Silicone fluid was able to withstand the most heat of any brake fluid, so it earned a reputation as a racing brake fluid. However, silicone brake fluid has properties very different from glycol fluid, and has its own pros and cons. On the advantage side, silicone fluid will not harm paint or plastic, and does not aggressively attract additional moisture as glycol fluid does. On the disadvantage side however, silicone fluid aerates easily. Harley-Davison, one of the sole current OEM users of silicone fluid, warns buyers to let the fluid sit at least an hour before using it. The trip home in the saddlebag is enough to aerate silicone brake fluid until it looks like a freshly poured soft drink. Silicone fluid is also slightly more compressible than glycol fluid, does not change color to tip the user to its moisture content, and worst of all, neither accepts or disperses moisture, making systems using it more corrosion prone, and requiring much more frequent fluid changes. Silicone brake fluid also lacks glycol fluid's naturally occuring lubricity, making it incompatible with the mechanical valving in some antilock braking systems"
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #708321 21st May 2018 10:06am
NoDo$h
If you have used DOT5, buy yourself 5l of DOT4 immediately and start flushing..... You may still expect to have problems with your ABS pump and with your calipers so another flush may be needed
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #708323 21st May 2018 10:18am
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Re: Two new front calipers soft pedal
How did you bleed the system, two guys, one pressing the pedal and the other opening and closing the bleed nipple?
Or did you go with pressurized approach?
Post #708524 22nd May 2018 6:50am
jst
only just seen this and was going to reply but i was too late and have been told anyway! Shocked Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #708575 22nd May 2018 11:44am
4RF RDS
No oressure bleed just the old fashioned way. All good now, deffective part out of the box. Re-bled entire system with a couple litres of DOT 4 to get the DOT 5 out. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #708629 22nd May 2018 6:40pm
NoDo$h
Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #708740 23rd May 2018 11:16am
