Home > Td5 > So the 2000 x reg has turned into a 2004 td5 xs.
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
So I saw and test drove another defender 110 td5 - xs this time, felt a bit more close to the door and not as high.(I test drove the country wagon on Wednesday gone)... Is that part of the xs model?
It's up for 17k, drove lush, no issues like the one before, little bit of rust underneath. And some scratches on the paint work but all good otherwise. 76000 on the clock, 2004 registration. Roof bars and winch (which I didn't get to test, but will see on pick up)
Plenty of pull, breaks good. Smooth drive, no clunky gears, tried diff lock all good. Didn't get to try with 4x4, but access seemed clean...
It failed the mot with the rear shocks leaking and lamp(I think), but they are fitting new ones before I buy it.
What your thoughts all?
Post #708000 19th May 2018 12:17am
bankz5152
Sounds quite reasonable. Id offer £16k, got a link?
Also go back and check the previous MOT history
Post #708027 19th May 2018 9:16am
Adam17
I tried to knock them down, but they have already dropped 1k, I have put my deposit on it already.
I am going back Monday with a chap I know through metal detecting, he owns 2 defenders and is coming with me to give it the once over.
here's the link
http://www.allensvans.co.uk/used-results/l...fender-110
Post #708038 19th May 2018 10:39am
bankz5152
Quite tidy!! I like it. Make sure the AC works!
Post #708039 19th May 2018 10:51am
Adam17
Thanks chap
Post #708040 19th May 2018 10:54am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Underneath doesn't look to bad, wire brush and waxyoyl asap will give it a new lease of life.
Has not been detailed which is a pity as its on the forecourt Rolling Eyes
If they have dropped £1k already it means it hasn't sold for a while therefore i would go back and try £16k. The extra money could be put towards the underside clean up.
When was the clutch changed / has it been changed. Some of the guys on here might be able to comment on clutch longevity. I had one at about 25k but it is remapped. Think my case was a faulty dual mass flywheel. Been fine since changing clutch and flywheel. 76k is not bad if it has a good service history.
Other than that looks great for its age and some nice extras, bet you can't wait Thumbs Up 2007 TD5 90 Hard Top
Post #708042 19th May 2018 11:09am
VVS210
Based on what you said about the first one you drove this one is in a different league.
As others have said, check the MOT history on DVLA website to see if mileage is gen & get an idea of what's been done to it in the past. Also ask to see service paperwork not just a stamped book... A full HPI check is also well worth the £20 it costs as it will throw up how many owners, insuranxe write off, etc. - all done online & starting with the reg number but more details if you have VIN no.
Looks like the winch has seem some action so give everything the once over underneath as it's very probably been off roadbed - not a bad thing as long as it's been looked after accordingly.
It has certainly got a few mods on it so I suggest that you check with your insurers as things like the winch bumper, 2" tow hitch & roof rack are a no no for most of the household names. bump stops are non standard so guessing it has poly ushers as well, insurers need to know all these things so might be worth taking a pen & paper with you.
Looks like a good truck, although I am clearly out of touch with the market value as that seems a lot of money for a 14 year old 110 Shocked
Post #708043 19th May 2018 11:09am
bankz5152
Tax is wrong too should be £230.00 p.a
Prices are high for the TD5s my 110 XS bog standard 1 owner 90k FSH was £12k 2 years ago. Since then ive not found one even close for less than £17k so this is about right.
Check the fuel filter housing they can corrode and often missed (drivers side rear wheel arch).
Ive found TD5 clutches are a fickle thing my 90 went through two and one DMF in 20k miles which was mildly mapped and only did maybe 5k per yet my 110 is heavily mapped and on 105k driven daily and is fine.
Post #708046 19th May 2018 11:37am
Adam17
Thanks for the info all.
As mentioned, I have a buddy coming with me to check it over, he owns a 300tdi & 200tdi, so knows a great deal more than me.
Post #708049 19th May 2018 11:47am
bankz5152
There are a few things that are TD5 specific to look for which could be potential issues down the line or cost you money if you don't pick up on them before sale.
Few 110 TD5 specific things I would check are
Oil in the red plug in the ECU (under drivers seat)
Fuel Filter housing corrosion (under drivers side rear wheel arch)
Check the A/C works properly - I forgot to do so and needs repair, which I havnt gotten around to yet
Pull the carpet up where the rear seats mount to the seatbox, its a big area of corrosion, mine was utterly rotten
Post #708052 19th May 2018 12:27pm
VVS210
Just taxed my County DCPU - reminder was £240 but post budget it was £250 - it's a 2002 Td5 15P engine.
Post #708071 19th May 2018 3:03pm
bankz5152
How odd! My 02 90 CSW was £280 per year! The 04/05s are £230 and 06/07 are £500+
Post #708074 19th May 2018 3:22pm
NickMc
Can you not buy a newer Puma for that sort of money?
I think the other one was well priced because of the Galvanised Chassis. That’s a nice spec truck, but it does have a lot of scorpion racing aftermarket bits on it.
2006 is the year they went tax mad hence why you always see 06 models for cheaper than others like disco 3’s and Double cabs etc
Post #708078 19th May 2018 4:14pm
bankz5152
Not an XS spec one no. Plus depends if you want a Puma, I chose a TD5 as i prefer them.
Post #708081 19th May 2018 4:43pm
NickMc
I reckon you could get a base spec Tdci CSW for that money. I think Td5 chassis’s were made out of recycled bean cans, thoroughly check the Chassis, especially where the two holes in the side rails are in front of the rear crossmember real mud trap.
It’s a COUNTY station wagon not Country Thumbs Up Rivet counter hat on Laughing
Post #708145 19th May 2018 10:42pm
