Home > Maintenance & Modifications > Cheap Crimper |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
Have you got a link? I bought a cheapo Chinese made Hydraulic Crimper, for 4 to 70mm² Cable, on eBay 4 years ago. I've used it for lots of projects and it's still going strong I don't know if it would stand up to professional everyday use, but for what most vehicle tinkerers want, they're ideal. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
12th May 2011 6:32pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Why not solder the ends? _ We used to do that on the fire engines years ago.
12th May 2011 7:41pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I agree with ickle. You get a much stronger hold and better conductivity from a soldered joint. I had to spend hours on end in the footwells of Mastiff armored vehicles in 50-60 degree Celsius heat because Thales in their ultimate wisdom decided to crimp all the connections and they were working their way loose in the heat and the vibrations. Reminds me I need to get some heat shrink and solder for the weekend for a few jobs Glyn |
12th May 2011 7:52pm |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 |
A soldered joint is far more likley to break in a high vibration environment. A correctly made crimp is better in those circumstances.
When you solder a joint you end up with a solid lump upto the end of the solder. This then becomes the point at which the copper is moving, and then very quickly work hardens and snaps. A crimped joint will allow a degree or movement meaning it can flex, which spreads the stresses out. Mark [:O|===|O:] 2001 110 TD5 Doublecab |
12th May 2011 11:41pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
I think there is a case for both, i have in the past soldered one and then crimped it too. Even if you dont solder the wire into the connector then its a good idea to tin the end of the wires before crimping.
My crimper is only a cheap (about £35 uk) one and looks like a question mark if you hold it up. It does the job very well, leaves a nice tidy job and ive not had any problems at all with it. It does come with spare seals though, so i guess they are a weak point. If you want any more details then just drop me a message. Pete. |
13th May 2011 12:26am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Thanks for the good oil on the crimper!
PaulMc / Zinke it could be the same one as you have, 4 to 70 mm with spare seals. Yes there are some valid points regarding solder and crimping, over here the thinking is solder is not suitable for the corregations. However solder does create lower resistance and strength. |
13th May 2011 1:53am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16939 |
Absolutely right! Apart from the high cost of inidital tooling, crimp and/or IDC connectors are both cheaper and more reliable. If you do opt for a soldered joint, then you must ensure that you use a non-corrosive flux, and you also need to support the joint so that any movement is excluded from the soldered area. The best way to do this is with a high quality, preferably adhesive lined, heat-shrink sleeve. By the time you factor in the cost of labour to do this in a commercial environment, it soon becomes a very expensive option. Modern lead-free solders are also not actually as suitable as the old lead/tin alloys, but I suppose the fact that the fumes won't kill you eventually might be considered a benefit! I spent 25 years working in a design capacity for a major electronics/defence/telecomms company and we woudl very very rarely use soldered terminals. |
13th May 2011 8:22am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Solder v crimp or solder and crimp?
People will discuss the merits of each method. We normally crimp. If fitting a small diameter wire to a large tube terminal then we solder (i.e. compressor on an Anderson connector) If you decide to go down solder and crimp route I understand that it is better to crimp first and solder second. Reason being that if you crimp a solder joint the forces involved in crimping can fracture the solder. Brendan |
13th May 2011 8:31am |
^^^ For me there wouldn't be any other option. Fortunatly for me all the materials are sourced at a very very very cheap cost (thankyou everyone ), and yes it is a very long process of about 10mins per terminal from start to finish compared to about 3mins to crimp and heat shrink. But when you are on top of a vehicle in the middle of Afghanistan repairing 'crimped' joints that have worked loose on a remote weapon system you quickly learn to hate crimps. I agree that crimps are now recognised as the norm, but that is only due to cost. I have NEVER had one of my solder joints fail on me compared to hundreds of crimp joints I have had to repair. If you have play in a termination there is the possibility of failure- a little movement will work its way to a lot of movement and then fall out. I would also say bombing through the desert of Afghanistan in vehicles weighing 50 tons on leaf springs creates more vibrations than a coil sprung Defender weighing less than 3 tons. Glyn |
13th May 2011 9:45am |
Aha, I agree entirely, but you (and I) know how to do them properly! |
13th May 2011 11:56am |
Why on earth would anyone even consider for a moment soldering then crimping? It would be a completely barmy thing to do, and would probably break something! |
13th May 2011 11:58am |
Brendan, I'm sure that you're aware that genuine Anderson connectors, when bought from a retail seller as a complete connector, i.e. housing and 2 x contacts, are generally supplied with contacts to fit the commonest cable size used with that particular model of connector. Other complete connectors are available to fit a range of cable sizes, as are different sized contacts and reducing bushings, which enable a wider range of cables to be accomodated by the available range of contacts. Anderson's data sheet library has some useful info - http://www.andersonpower.com/products/datasheets.html For the commonly used SB175, the data sheet gives details of available contacts, as well as the reducing bushings available - http://www.andersonpower.com/litlib/files.html/download/156 Anderson also give details on crimping or soldering the contacts, but recommend that, if soldered, cable clamps should be used with unsupported cables - http://www.andersonpower.com/products/use.html . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
13th May 2011 12:22pm |
