![]() | Home > Maintenance & Modifications > Gas Bottle Holder |
Like this?
https://www.ebay.co.uk/itm/Gas-Bottle-Hold...0677.m4598 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
I wouldn't want to trust a bit of plastic to hold a gas canister in an accident... you might well find a 5kg propane bottle where your head used to be
the proper holders are expensive for a good reason - especially important when it will be inside with you ![]() |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 409 ![]() ![]() ![]() |
I think the OP was referring to this http://maverick4x4.co.uk/index.php?act=vie...uctId=1540 The plastic ones are usually used inside a gas locker where the bottle can't really move too far if the plastic strap breaks.
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
There was a general release from the H.S.E., which I cannot find at the moment, advising NOT to carry gas bottles of any description within a vehicle as the valves could not be guaranteed to close fully and seal against gas leaks. This followed a vehicle explosion that killed the two occupants this was due to the valve on the gas cylinder, which had been stored overnight within the vehicle, even when fully closed did not seal and allowed gas to escape into the vehicle which exploded when the radio was switched on. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
