Home > Puma (Tdci) > Ashcroft's MT82 Output shaft kit "leakage"
Page 2 of 2 <12
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Thanks a lot!
Post #573248 25th Oct 2016 8:33am
Okan
Hi!
I will receive my kit asap. So does someone know if it's still necessary to put some grease on the shaft during the install like says the LR workshop or not with these "leakage" kit?
best regards
Post #575341 3rd Nov 2016 11:57pm
Since after the kit is fitted it will be lubricated with gearbox oil, I would suggest that the best course of action would be tto assemble it thoroughly lubricated with gearbox oil, not grease.
Post #575396 4th Nov 2016 9:59am
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
I fitted the kit to my 2012 90 at 69000 miles after going just out of warranty having had Land Rover replace 3 std shafts foc, its now done 82000 miles with no cluncks , I did cover the splines with grease thinking it would take a while for the oil to make its way up there 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #575556 4th Nov 2016 11:08pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Picked up my 2012 90 two days ago after having its 75000 Km service.
All good, except there is now the dreaded rust showing from the output shaft opening. My trusted workshop recommended we replace the shaft asap, and the various threads on this marvelous forum confirm that. Thumbs Up Thumbs Up Thumbs Up
The workshop, who look after a number of heavily modified and hard driven Defenders, have fitted a couple of Ashcroft shafts to customer vehicles in the past with good results.
I ordered the kit, and we´ll fit it as sonn as it arrives. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #575577 5th Nov 2016 8:41am
Okan
Hi all!
I can tell you that my output shaft ashcroft kit was successfuly installed on my one ten puma. No more clunk noise at all since it was installed. We put some cooper grease for the install and then we hope that gearbok oil will make his job.
I ll let you know in the future but at this time I m realy happy with it.
Best regards
Post #584041 11th Dec 2016 10:23am
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi Okan,
I am in the stage to put the Ascroft output shaft in too. Why copper grease? doesn't that interfere with the self-lubrication design of the shaft?
Post #584234 11th Dec 2016 9:22pm
Okan
Hi!
It was the only grease we had to install it. That's how we made it for install but the better is to ask to Ashcroft. I don't think that could be worst than without any lubrification and we didn't know how many time to lubrify the shaft by "leakage"
regards
Post #584296 11th Dec 2016 10:53pm
olliecracker
United Kingdom 2009 Defender 110 Puma 2.4 HT Keswick Green
Hi all!
The dreaded clunk is getting worse and I'm thinking of getting the ashcroft kit ordered this week!.
Just wondering if anyone who has installed the kit has had any of the dreaded clunk noises come back? - I take it that this output shaft change is a must from all the initial reviews I've seen!
Cheers,
Ollie
Post #707360 15th May 2018 7:08pm
I've not heard of one failing yet.
Post #707369 15th May 2018 7:26pm
NickMc
Not had one fail yet nor do I think it will. Speak to Ashcroft’s if you have any technical questions they’re great to deal with!
Post #707442 15th May 2018 11:02pm
Page 2 of 2 <12
