Home > Wheels & Tyres > Correct centre bore for defender alloys |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Hi what is the correct centre bore for defender alloys I have seen them go from 113mm to 117mm does this matter to much. Also what is minimum load rating for 110 alloys.
Thanks Andy |
15th May 2018 9:16am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
I believe it’s 114mm centre bore 2014 Keswick Utility 2.2
15th May 2018 1:11pm |
So long as the bore is at least big enough it doesn't matter. It doesn't use the bore to centre them or take any load so it's not critical.
As for wheel rating, the maximum rear axle rating of a 110 is 1980kg: https://topix.landrover.jlrext.com/topix/s...d367/en_GB So the absolute minimum rating for a wheel would be 990kg. A worst case scenario would be cross axled at full GVM so all the weight on one wheel but that's pretty unlikely. Obviously dynamic loading as you hit bumps would take that much higher and cornering will also put more load on the outside wheel. |
16th May 2018 11:51am |
Thanks guys very helpful.
16th May 2018 5:57pm |
MadTom: ah, I didn't know that, thanks
Sorry to have peddled incorrect information, I've only ever used steel wheels. |
17th May 2018 10:24am |
