Home > Technical > Clutch Hose pressure
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Who knows the pressure in the clutch hose?
I found larger flexible hoses that are up to 500psi, i rather make a hose that goes up to 1500psi, but the fittings are a problem. They dont have swivle m10x1 in ss braided hose
Post #706901 13th May 2018 2:03pm
zsd-puma
I doubt it's much at all to be honest. I mean think how much effort it takes to compress the fingers on the clutch cover. If you put one on the floor and stand on it it compresses easily.
That's what? 170lb on about 2 square inches. So if roughly 85psi is all it takes to compress the clutch, I doubt the hydraulics have much more than that in them.
Post #706912 13th May 2018 3:36pm
Naf
The pedal needs about 25lb to move.
Ok, i will try the 500psi hose and if it busts, i will try something a bit higher in workin pressure
Post #706915 13th May 2018 3:41pm
zsd-puma
That's a more scientific way of working it out.
If you know the pressure to depress the pedal and can find out the piston sizes for the master and slave cylinders you can work out the multiplication factor. But even if the slave is 4 times bigger than the master, that's only 100pounds.
Post #706985 13th May 2018 8:22pm
Naf
Lost in translation, they supplied a hose with a workin pressure of 300bar and a burst pressure of 500bar.
I am in the clear
Installin and bleedin tomorrow
Post #707102 14th May 2018 1:09pm
