![]() | Home > Technical > Let's talk about my nuts.... |
Have just gutted the DC, including removing the dash and lifting out the transmission cover etc, all in aid of a number of jobs to prep the Def until the next big strip out, hopefully no less than a decade away. I'm keen to lift the floor panels up, to give them a good clean before sound-proofing, sealing and re-fitting, but as Mrs Grenadier is unlikely to find herself under the chassis, and my arms are not as long as Mr Tickle's, I cannot work out how to remove the bolts towards the transmission tunnel or mid-point on the rear passenger floor panel. Does anyone have a clever trick (or recommend a tool) to hold the nut in place under the panel, whilst undoing the bolt from the top? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I thought they were just screwed down into plastic clips? Ray
Mine don't seem to be. Hex bolts all round. But then having stripped this back, a lot is not what it seems (or the stealer claimed it) to be. Lucky I bough the DC with the intention of fully stripping it back and eventually re-doing everything from the ground up. But some of the DIY stuff under the skin is frankly laughable. And I bought from the stealer because I thought they had a good reputation... Monsieur Le Grenadier
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
I've taken mine apart a couple of times and it was screwed into plastic clips with fat self tapping screws. Same type as the front grill.
JMG Member Since: 16 Apr 2014 Location: Surrey Posts: 222 ![]() ![]() ![]() |
The grinder is your best friend here, whip off the tops and punch em through
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
I had to resort to the neighbours help when I fitted my rear mud shields- I simply couldn’t get the nut onto the screw and hold the top of the screw all at the same time.
A gizmo would be useful, but not sure how you could do it. 2014 Keswick Utility 2.2 |
