Home > Puma (Tdci) > no drive at all - output shaft dies @ 65 000 km
Page 2 of 3 <123>
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
NickMc wrote:
I would go for the Ashcroft solution if you want zero maintenance. I’m sure it is well thought out product, t the end of the day they’re Land Rover gearbox specialist so I’m sure they’ve seen a lot of failures to come up with a solution that works. Their after sales service is second to none, the advice is always free and I’ve had Dave contact me after hours because “I didn’t want to leave you waiting” cant ask for more than that in my eyes Bow down
Ditto the above...
You just have to be careful when installing the kit that you don't nick the sealing o-rings...
My original install had a leak, but Dave Ashcroft was a total gent, and sorted it quicker than you can blink..
Most definitely worth fitting.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #706517 10th May 2018 11:31pm
Given that the failure gives absolutely no warning and can completely disable the vehicle should it not be subject to a recall in the same way bmw have been shamed this week?
Post #706522 11th May 2018 6:58am
UtilityTruck
Well, nobody died... 2014 Keswick Utility 2.2
Post #706523 11th May 2018 7:17am
Oh I get it, someone needs to be killed before it’s taken seriously
Post #706525 11th May 2018 7:24am
Pickles
It happened to us, not in a really remote area, but about 300klms from home, ,....in 30C temps, took 4+ hrs for LR assist to get to us...DEVASTATING, We felt absolutely helpless,....I cannot imagine what a total loss of drive would be like in a REALLY remote area.
Pickles.
Post #706527 11th May 2018 7:53am
I have often thought this. What would happen, for example, if it failed as you pulled a heavy trailer onto a level crossing?
Landrover has, in my opinion, an extremely cavalier attitude to vehicle recalls and manages - somehow - to get away with dangerous faults by means of service actions and "only do it if the customer complains" type repairs.
The number of total drive failures due to the flawed implementation of what should be a simple and well understood drive coupling is by any standards appalling and it continues to surprise me that a recall has been avoided. Some high profile deaths would undoubtedly help.
Post #706533 11th May 2018 8:22am
zsd-puma
you get out and use the emergency telephone on the crossing. Signalman puts a block on the line. Unless you were daft enough to race the lights, theres plenty of time for trains to stop.
But yes you're right, its appalling customer service from Land Rover.
Post #706553 11th May 2018 11:19am
zsd-puma wrote:
... there's plenty of time for trains to stop.
Not necessarily. If the train strikes in at the moment of shaft failure it is very unlikely that the train could be stopped in time.
Post #706559 11th May 2018 12:19pm
zsd-puma
That would only happen if you'd been racing the lights. Wink
They do take into account that pedestrians could fall over, road vehicles could run out of fuel, have an engine failure or have clutch failure when they set the timings for the signals.
If it's a manual crossing, you have to phone the signalman first, and phone again when you're clear. If you don't phone back they order the train to proceed with caution at reduced speed - to cover just such an eventuality.
There's probably more of a risk if it failed on a busy motorway.
Post #706580 11th May 2018 3:18pm
dorsetsmith
Julie
Surprisingly, the MT82 shaft is not the first "dry shaft" in the history of the defender.
Land Rover made the same mistake with the LT77 / Defender TDI 200:
MT 82 is ford gearbox sham ford made the same mistake Exclamation
Post #706583 11th May 2018 3:31pm
diduan
Bulgaria
I had the same issue with the output shaft last year, luckily only 5kms from home Very Happy
But you can hear it dying, it made click-click sounds some days before it actually died. Most noticeable when maneuvering in 1st gear, then reverse etc.
Greetings, Delyan Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #706585 11th May 2018 3:35pm
dorsetsmith wrote:
Julie
There is nothing fundamentally wrong with the MT82, it is a good gearbox (unless you're a Mustang owner, of course), and (apart from being the parent of JLR at the time) Ford had nothing to with the output adaptor shaft design, that was all down to the JLR team tasked with fitting the Ford engine and primary gearbox into the Defender.
Nothing about the installation was particularly good, unfortunately, from fuel system to output adaptor shaft to CANbus hack.
Post #706587 11th May 2018 3:41pm
Sorry to labour this point, but rail industry standards* specify that the minimum time from a train 'striking in' and commencing the closure sequence of an automatic crossing to it arriving at the crossing is 27 seconds. If you are on the crossing and suffer a complete loss of drive as the train strikes in, and the train is travelling at maximum permitted line speed, you have may have only 27 seconds to get clear of the crossing. By the time you have stopped, cursed, tried the difflock, wondered what to do next, and looked helplessly around for a telephone, you will be dead. If you have great presence of mind and are really on the ball you and your family will be clear of the crossing by the time your Defender is obliterated.
Very few crossings are protected by signals (usually only in the case that the crossing is in advance of a station) and there is no power on earth that will stop such a train before it reaches the crossing.
* Specifically Railway Group Standard GI/RT7012, which has now been superseded, although he minimum timings have not as far as I know changed.
Post #706589 11th May 2018 3:59pm
zsd-puma
Most of the crossings I've seen start the warning lights and lower the barriers long before the train arrives, certainly in this area, I'd bet only a handful of crossings actually use bang on the 'minimum' timing. Stopping the train is simply a case of the signalman making a REC to all trains in the area ordering the driver of train xxxx to make an emergency stop, it comes out over the cab speaker of all train in the area. Emergency phones are pretty obvious yellow boxes on both sides of the crossings.
I still think there would be a much greater risk if you lost drive in the middle lane of a busy motorway. I experienced this in an old Volvo when the throttle cable snapped. Most people aren't willing to give way to you when you're trying to coast to the hard shoulder.
Post #706596 11th May 2018 4:44pm
zsd-puma
Agreed, they just bought in the gearboxes from Ford, then Land Rover worked out how to marry the Land Rover transfer box with the Transit/Ranger gearbox. The Ranger doesn't suffer the same issue with the gearbox/transferbox interface that the Defender does, because Ford/Getrag designed the whole transmission. If it had been down to Ford, then I've no doubt Land Rover would have got it sorted more quickly, as they'd have claimed the cost of it from Ford.
Land Rover should have come up with a solution much more quickly though I mean they had 9 years. Even if they sealed the adaptor shaft housing and fitted filler/drain bungs so it could be filled it with oil!
Post #706599 11th May 2018 4:52pm
Page 2 of 3 <123>
