Home > Maintenance & Modifications > 2.4 EGR PATCH
LR90XS2011
2.4 EGR PATCH
Anyone had an EGR patch on a 2.4 PUMA with no other tune , if so can you comment on any noticeable difference. DEFENDER 90 TDCI XS,
Post #705579 6th May 2018 6:51am
Caterham
no but highly recommend you get it done - keeping the engine cleaner and boost your mpg by 10%.
you're not far away. you should come try mine with 100k miles the engine is sweet as can be.
Post #705596 6th May 2018 9:18am
I've had both, but EGR shut down is very easy.
You can also have it programmed for complet shut down, or just with cleaning cycle still running but no EGR activity whilst running.
At least with Alive you can, I'm sure others are similar.
I'm sure, if you mention to Gary @Alive that I recommended him he may may be able to work something out for you if it's just an EGR shutdown only.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #705620 6th May 2018 12:16pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Yes - started with a BAS egr delete - all good - had the remote tuning device (Useful for fault code reading and clearing) so had a remap later - total revelation transformed drivability. Have since found that Pete's customer service is second to none.
Post #705624 6th May 2018 12:50pm
