![]() | Home > Technical > Flasher unit location?? |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Know it for a Puma, but not for Td5. But the flasher clicking sound is produced by the relay. So try to locate where that sound comes from and you should find the relay.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Behind the dash clocks
![]() My build thread http://www.defender2.net/forum/topic17615.html |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Yep, behind the dash clock, but don’t bother putting the dash back on until you’ve done all the indicators as you need to be able to adjust the variable resistor. This will stop your trailer indicator light from coming on with every flash.
Green&Gold Member Since: 13 Oct 2014 Location: Surrey Posts: 7 ![]() ![]() ![]() |
Wish I had read this earlier…. Sitting with the entire fuse box unscrewed looking for it.. thanks bluebottle
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
yeah its behind the dash clocks, its a black relay, but put the hazards and have a feel for a clicking relay
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
