![]() | Home > Technical > 300 TDi Rocker Shaft snapped |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
I've experienced a broken rocker shaft on a 300. Usually follows a broken cam belt. I bought a genuine shaft and didn't have a problem.
Roosterrs Member Since: 19 Feb 2016 Location: Northants Posts: 48 ![]() ![]() |
I think the rear stud thread in the head has yielded. This has then reduced the clamp load on the post clamp and caused it to move about. Finally the head thread has sheared and this has caused the rocker shaft to break. I have noticed a drop in performance but thought it was just me. There is no piston to valve contact. Cam belt hasn’t failed. Did have a high rev incident where I had to change down quite quickly to make a corner where they had blocked a road for roadworks just over the brow of a hill so could have been that but the slight loss of performance was already there so maybe it was a combination of the two.
Yup, I had to helicoil 2 of mine that had stripped in the head. Mine broke a few months after cam belt failure and I've read on forums of a least 2 or 3 other incidences so it's by no means unknown.
It was chuffing out of the RAI because of the valve overlap which those with me at the time found very entertaining 😉 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
