![]() | Home > In Car Electronics > New RAM Phone Mount Fitted |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Same location as I use mine.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
Can you share the component numbers and more photos of your install?
I'm interested to do this for my phone and trying to figure out a better mounting option for my Garmin unit as the stupid suction cup thing that came with it now falls off at least once a day and it can get annoying especially if you're following it off road and it falls off! Thanks in advance! |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Hi HardCharger, I used the 1inch ball adapter with the 9mm hole in the base here https://www.mudstuff.co.uk/products/ram-mo...hball.html this fixes to the existing screw mounting at the top of the dash. Then just fit a phone holder or device mount here https://www.mudstuff.co.uk/products/ram-mo...older.html with the extension arm here https://www.mudstuff.co.uk/products/ram-mo...l-arm.html
No drilling required and I have run a charge cable up the dashboard from an existing usb connector from my head unit. Hope that helps. Slightly better picture of the dashboard fixing here ![]() Click image to enlarge |
Many thanks, Scoobeenut!
Those help a lot! |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2503 ![]() ![]() |
Just curious will the x grip fit a iPhone 8 Plus with a lifeproof case on its pretty chunky! too big for my trusty old Tesco phone holder! 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Mine takes the samsung 8 plus in an otter box.
