Home > Td5 > How do you check the transmission fluid level?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Hi there,
Sorry for the Noob question but just wondering if there is a way to check the transmission fluid level. The fluid is red (see the pic) so I assume that’s what it is. I just had the entire clutch and transfer case rebuilt...
Thanks!
 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #704898 2nd May 2018 10:22pm
The level on those boxes is 'fill to spill' so just top it up to the filler hole. Darren
Post #704901 2nd May 2018 10:28pm
BCdefender
Thanks! 1999 Defender 110
2003 P38
2007 RR SC
Post #704904 2nd May 2018 10:33pm
roel
If it is red I think it is the gearbox oil. The fill plug id on the side half way up.
The transferbox oil stinks and is more brown. and the fill plug is at the back near the hand brake drum.
I can't really see where the leak is. Roel
2003 90 Td5 (2009-now)
Post #705046 3rd May 2018 6:49pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I see you have a Roamerdrive high capacity sump. Do you also have a Roamerdrive? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #705049 3rd May 2018 6:55pm
BCdefender
Yea. I can't really see where the leak is either. Its a bit odd as there seems to be drips collecting in three different areas 1999 Defender 110
2003 P38
2007 RR SC
Post #705482 5th May 2018 6:11pm
BCdefender
Yes, installed the roamerdrive shortly after shipping my Defender over here. Makes a huge difference for longer drives... 1999 Defender 110
2003 P38
2007 RR SC
Post #705483 5th May 2018 6:12pm
4RF RDS
The synthetic oil specified for the Roamerdrive leaks more easily than the 90 wt oil LR specifies for the LT230 T-case. Some of those drips look to be from the t-case. I have the same issue. Never leaked till I put the synth oil in to it when I installed my Roamerdrive. It seems to weep more easily through the gaskets no matter how well they did not leak prior to the synth oil.
Just an observation. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #705486 5th May 2018 6:24pm
BCdefender
Thanks for the reply. Here is a close up of what I think is the gear box. Colour looks red to me which indicates it’s gear box ie transmission fluid as opposed to transfer case fluid?
 1999 Defender 110
2003 P38
2007 RR SC
Post #705507 5th May 2018 7:27pm
4RF RDS
Yes that looks like ATF which many put in the gearbox. If you cannot see where it is leaking from, a spot I found on many gearboxes is the top shift tower. Where it mates to the gearbox. You can access it from the top middle plate between the seats. It cleverly weeps down the gasket and makes it very difficult to trace. If it is wet up there that is likely where it is coming from. Four bolts lifts it then seal it nad put it back👍
1967 MGB GT
Post #705547 5th May 2018 9:30pm
BCdefender
Thanks! Time to dust of the RAVE CD and look at the parts book! 1999 Defender 110
2003 P38
2007 RR SC
Post #705665 6th May 2018 8:08pm
