Home > Puma (Tdci) > Broken halfshaft
Broken halfshaft
Driving home from work just now, started to pull out at a junction, then bang! followed by a lot of clattering with total loss of drive. Big Cry Coasted to side of road to investigate - engaging gear results in the rear propshaft rotating, bad noises, and no drive. Lock up the centre diff and vehicle drives with only a few more bad noises than usual. Conclusion - rear halfshaft gone.
Has anyone here changed one on a puma and got any tips? I imagine it is the long one, it usually is. Is it possible to get the broken end out without taking the diff out? Any idea how much a halfshaft costs?
Ironically the defender is booked in tomorrow for the handbrake recall but I don't think a 40 mile journey with a broken halfshaft would be a good idea.
Post #70466 10th May 2011 9:47pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
there easy to change only 5 bolts and out it should slide ?
you could be lucky and its broke the wheel end overwise a good strong magnet can get them out of the diff i think x-eng do one
and half shafts shouldnt be to bad iv got ashcrofts though so i dont know
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #70467 10th May 2011 9:52pm
Thanks Steve! Will get up early and pull the shafts to find out what's broken.
I see online that new genuine shafts are £250+ but B***part and others are £30 or so. Hmm, I wonder which are better quality! It should be poss to get a pair of Ashcroft shafts for the price of one genuine one, provided they're in stock and can be shipped quickly enough - I need to be mobile again by the weekend. After tax, mot and insurance this month I could have done without this! Never mind, all part of the Defender experience.
Post #70479 10th May 2011 11:32pm
BigMike
To be honest bw if you get ashcroft shafts, whilst theyre great you're just moving the possible problem down the line ie cv or gearbox. Id be interested in why one broke in those circumstances unless you've been excessively stressing and or shock loading them offroad etc. Depending on the age of the vehicle, if its new i would want to look at a few other things as well as the broek shaft. if older then a different story. But still, I wouldnt get uprated ones, just OEM, and NO way I would buy from britpart etc.
Post #70481 10th May 2011 11:53pm
AndrewS
Call Land Rover Assist and get recovered to a dealer of your choice and get it fixed under warranty. If you do this Land Rover will supply you with a car whilst yours is being repaired. 130's have feeling's as well you know Smile
Post #70487 11th May 2011 7:05am
It's an 07 DC and well out of warranty unfortunately. I am wondering myself why if failed since I have been driving LRs for over 30 years and have never broken one before. I am running 285s but don't see why this should make a significant difference.
Just going to pull the shafts now, will post my findings.
Post #70492 11th May 2011 7:19am
OK, pulled the long shaft first, intact, but the driving member is worryingly loose on the splines at the outer end. Then pulled the short shaft, also intact, however the driving member rotates on the splines at the outer end, the splines have stripped completely.
So, I need a pair of halfshafts and a pair of driving members. Good news - in stock at local dealer, bad news - halfshafts £250 each, driving members £100 each Shocked .
Can anyone tell me if the driving member should be loctited on the halfshaft or fitted dry/lubed? I seem vaguely to recall there being a service bulletin on the subject.
Thanks.
Post #70499 11th May 2011 9:33am
AndrewS
Locktite the splines on the drive flange and the bolts. 130's have feeling's as well you know Smile
Post #70575 11th May 2011 8:15pm
ickle
Are the shaft splines worn away or just the driving members? The halfshafts seem to be very hard & the driving members just cast iron, I replaced the rear ones on Ickle to reduce some of the driveline clunk, the shafts were unworn, the driving members pretty sh@gged!
Post #70593 11th May 2011 10:17pm
Both the shafts and the driving members are shot - will try to post photo in due course. A pair of nice new genuine ones are now standing in the kitchen to let the loctite 648 cure overnight, will fit tomorrow.
Post #70601 11th May 2011 11:03pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
It's it ok to loctite.I thought the shafts have to be floating in the axle.I think there was a Td5 Defender with the drive flange fixed to the shaft and wonder why it was done away with. Puma 110 SW
90 V8 SOFT TOP
Post #70624 12th May 2011 10:02am
MK
I see all the time people recommending Ashcroft half shaft. KAM ones are never mentioned. Anybody have used KAM? Puma 110" SW
Post #70628 12th May 2011 10:27am
All back together now and much nicer to drive, with far less backlash in the drivetrain.
The question of Loctite or no Loctite is an interesting one. The dealer's line on this is that they don't loctite Defender drive members because "once some dirt gets in there is acts like a grinding paste" which makes no sense since no dirt will get in when it is Loctited, but it will if dry or greased.
Landrover recommends Loctite on Discovery and Range Rover drive members to prevent clunks and knocks, but doesn't on Defender despite these being broadly identical.
The Puma manual shows the 90 as having a member integral with the halfshaft and the 110 and 130 having seperate drive members and makes no mention of Loctite on the latter.
All in all, after weighing up the situation, I can see no possible harm at all at Loctiting the members to the halfshaft and potentially a lot of benefits. The only downside is that it may make it difficult to remove the drive member from the shaft, but there should never really be any need to do this, they should always be replaced as a pair anyway.
The Loctite product to use is Loctite 648, available as LR part no STC50554, the same as used on the diff pinion splines.
Post #70629 12th May 2011 10:41am
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 07 110 is waiting for a new rear diff, new 1/2 shafts and new drive flanges to come in (been waiting 3 weeks so far) and get replaced under extended warranty. The slop in the drive train is terrible and its only a matter of time before the flanges or 1/2 shafts go bang. I'm glad I took out the warranty extension when I started feeling things where getting bad late last year
Its only done 27K miles. What the hell went wrong with drive train quality on Puma Defenders? This is the 5th 110 I have had and the worst for drive train problems by a great margin.
Post #70736 12th May 2011 8:30pm
AndrewS
They are made from toffee, blame Ford Rolling Eyes 130's have feeling's as well you know Smile
Post #70737 12th May 2011 8:49pm
