Home > Tdi > Boost Ring & Pin
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Boost Ring & Pin
I have a 200tdi fitted in my old 110CSW which has the high ratio transfer box fitted. It was bought as a project although was solid and so I like twiddling and fiddling to try and improve it or counter the effects of age. I have adjusted the fuel pump to give it a little more umph and am wondering if anyone has experience of boost pins and rings that are now about? Its not about making it a race car etc as people may point out but more out of interest for me, seeing how it can be improved although a little extra power in hilly Yorkshire is always welcome.
Post #660388 29th Oct 2017 10:29pm
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Hi Steve recently fitted a boost pin to my 300tdi it has made some difference pulls away a little more eagerly but as you said yourself these aren't sports cars Rolling with laughter I think a clean intake system including intercooler would be money and time just as well spent
Simon
Post #668029 30th Nov 2017 6:43pm
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
I have fitted a boost pin to my 300tdi. Apart from this everything we is standard I haven't turned the pump up. I would recommend it. It drives the same as before unless I put my foot flat down then there is a lot more power. There is no need to drop a gear going up hills on the motorway anymore. There is a bit of black smoke but only under full acceleration with normal driving there is nothing.
Post #668397 2nd Dec 2017 11:22am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
No response about the Boost Ring from Steves post? My boost PIN has been adjusted and so the Fourby (other boost pins are available) Boost PIN is of no benefit But would i get any benefit from fitting the Fourby Boost RING on its own?? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #673072 24th Dec 2017 3:05pm
jst
we are talking in the FiP here i take it?
the std pin has more than enough profiles on it to give what you need without changing the pin. betting is any pin you will buy is only replicating an option on the original pin anyway.
best mod you can prob do is take the turbo waste gate pipe feed from the inlet manifold not the top of the turbo/ T piece. leave the FiP actuator from the turbo (will make it lazy) which is fine. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #673116 24th Dec 2017 6:40pm
steveyorks
JST I have heard mention of this before though don't really understand it. Can you explain a bit more please?
Post #690992 4th Mar 2018 10:35pm
jst
looking at Tdis here, and based on my experience after experimenting over 5years using EGT and Boost gauges.
the turbo wategate opens when 'max' boost has been reached
the wastegate is operated by a pressure pipe that is fed, usually, from the compressor side of the turbo. as the wastegate is on the turbo body its a very short piece of pipe.
lets say the tdi wastegate is designed to open at 1 bar as thats what they determine the engine can take. (note 1 bar i have chosen as an example rate varies for 200/300s)
so when the turbo is putting out 1bar at the compressor, the wastegate will open when the pressure in the aforementioned pipe reaches 1 bar.
the air will then pass through the intercooler to the inlet manifold. where .... it will be less than 1Bar due to losses in the pipework.
If the pressure feed for the wastegate was taken from the air inlet manifold (there is a blank at the back on some tdis) then the turbo would continue to spool up until you have 1 Bar at the air inlet. If the engine is designed to take 1 bar, it is now seeing the 1 Bar rather than say 0.8 Bar due to pipe loses.
In essence this uses the turbo to overcome the losses in the pipework between the turbo outlet and the inlet manifold.
If you fit a larger intercooler you may well see a pressure drop compared to the standard one, hence the hiflow ones etc.
by taking the feed off the air inlet you are guaranteeing the inlet will see the max pressure the turbo was matched to give to the engine. 1 bar in my example irrespective of pipe losses. So you dont need to know the pipe work losses.
if you just shorted the wastegate actuator rod (which will mean turbo needs to produce a greater pressure to open the wastegate) you are guessing at what extra pressure is needed to be generated to overcome changes/looses in pipework to get your 1bar at the inlet.
on mine, having done the intercooler and FiP pin and max fuel screw mods this matched the pressure and saw a jump from 0.9bar at manifold (std wastegate setup) to 1.3 bar at manifold, taking wastegate feed from inlet, under full boost. it was quicker off the mark and used less fuel.
The second part is the FiP pin which moves down under pressure.
The greater the pressure the further the pin moves down and then the higher the fuel delivery.
In standard this pressure feed comes from the same pipe as the wastegate pipe (its T'd in)
If you leave this feed here it means the FiP diaphragm will move down as the turbo instantly produces pressure.
If you moved this feed to the inlet manifold it would produce pressure and move the pin down still but the pressure would be less compared to the pressure at the original 'T' piece, due to losses in the pipework (from tubo to intercooler)
So to give the vehicle more low down you need to make the FiP pin move down asap, so therefore keep the FiP feed direct off the turbo. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #691151 5th Mar 2018 2:13pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
nice write up JST Thumbs Up ,got any pics of yours.
Post #691196 5th Mar 2018 5:23pm
steveyorks
A great write up I can see you have taken some time and care writing that so thanks very much. mines a 200tdi so when this snow clears I will have a look and see if I already have a place on the inlet manifold I can connect to. What type of pipework and fittings are required for this?
Post #691206 5th Mar 2018 6:17pm
jst
One of mine had a blanking plug at rear, bulkhead end, of air inlet so I used yet with 1/8npt thread iirc. Onto pneumatic 6m push fit. The other I drilled the casing and put thread in to take same.
Will have some pics at home somewhere, will dig them out. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #691263 5th Mar 2018 9:27pm
iamthehough
whats the best one?
Post #695980 24th Mar 2018 10:26pm
jst
Best boost pin? Or best something related to last post? Tap? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #695986 24th Mar 2018 10:42pm
tolley
Did mine the other day , only to find this .
Post #704810 2nd May 2018 5:18pm
jst
thats not the end of the world just clean it up, does the boost pin come out? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #704856 2nd May 2018 8:42pm
NickMc
Anyone who likes a bit of “light” reading there’s a Book by Bosch called Diesel engine management and it covers the VE Pump in depth.
Post #704867 2nd May 2018 9:12pm
