![]() | Home > Td5 > Intercooler refit - correct installation question |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8471 ![]() ![]() ![]() |
they do go there, is it std width intercooler?
not sure if they go inside or outside from memory. you may find if you have the top slam panel out or loose it will come in together when that goes back on without touching. i have had to space out some brackets at the bottom to miss 'extra' thick intercoolers before. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 271 ![]() ![]() ![]() |
Thanks JST,
I’ll try a loose fit assembly, as you suggest. Hopefully will become clear.l.... |
On the outside:
![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
