|  | Home > Technical > 300tdi leaky injectors |
| Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978    | What mileage has it done? My injector pump has just been rebuilt and injectors replaced at 187k. Not helped by discovering some numpty had wound up the dial on the pump and it was hosing out..... I expect fuel economy to be a bit better when the engine is finally rebuilt..... | ||
|  30th Apr 2018 12:11pm |
| buckers19 Member Since: 02 Jan 2018 Location: London Posts: 95    | It’s done a hair over 140 000. I’ve had a more thorough poke around and found that the leak off pipe was in 2 bits so replaced that so hopefully that will have solved the issue. | ||
|  30th Apr 2018 12:21pm |
| trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 521      | I was just about to say it's probably the leak off pipes, same happened on mine, they often get small cracks in and the diesel will run down the injector onto the clamp and make a mess. Give everything a good wipe down while you're there and then next time you go out in it you will be able to see if you've fixed it    Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html | ||
|  30th Apr 2018 4:05pm |
| buckers19 Member Since: 02 Jan 2018 Location: London Posts: 95    | Thanks Trickster, the offending area has been cleaned so will wait and see whether that was the issue, hopefully the bit of pipe lying around in the garage has saved me from filling up every 100 miles | ||
|  30th Apr 2018 4:55pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | leak off pipes
 https://www.ssldieselparts.co.uk/cotton-ov...p-661.html | ||
|  30th Apr 2018 5:16pm |
| trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 521      | I would do as Dorsetsmith suggests and buy some proper, snug fitting pipe or buy the whole leak off pipe kit off Paddocks including new washer and banjo bolts just to be safe - quite cheap Matt.
|  30th Apr 2018 6:59pm |
| Posting Rules
