Home > Tdi > turbo wastegate hose - £75 plus...!
donmacn
Hi guys,
I'm at the point where I'm having a good look at tuning options for my 300tdi.
I don't want speed, I just want more torque when towing. I regularly tow a boat weighing something a little more than a ton. Nowadays, I have to drop right down the gears on steep hills. I think I was in 2nd on the way home last weekend. It's very hard to remember precisely what I had to do 10 odd years ago, but I'm pretty sure I didn't have to do that.
So, I'm researching turbos, intercoolers, fuelling etc, but I think, before I start adding on any bits, that it would be good to have a baseline to work from - particularly knowing what the turbo is doing.
I've seen VDO gauges recommended. Fine, and I've also looked into where to fit it. I was planning to use the pipe to the wastegate actuator. I thought it would be a cunning plan to have a new hose available in case of any cutting 'cock ups', and to bring things back to standard afterwards.
Long-winded way of getting to the point. As far as I can see the part number is STC4617. Prices vary, but the cheapest I could find was £75 plus vat. It's only 12cm long! That's more than £6 for a cm of hose... It must be some high-spec hose to be that expensive.
What's the story with this, and are there any alternatives available?
Ta. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #704131 30th Apr 2018 11:24am
gilarion
Try fitting a length of fuel pipe cheap as chips. That is what I once did and the fuel pipe is a perfect fit diameter wise. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #704140 30th Apr 2018 12:38pm
donmacn
Thank you - I probably have some of that in the garage, whether for the car or boat. I'll use that for a 'no risk' boost gauge installation, which I plan to be pretty temporary anyway at this stage.
As someone more used to the 230 bar pressures involved in filling dive tanks I am genuinely interested though in why the proper part is so expensive - a wee bit of pipe, specified to handle 1.5bar max.
I know there doesn't necessarily have to be a rhyme or reason to it, I remember doing the bulk-head swap, I'd go to the dealer parts desk and be told that 'x' little plastic thing was £10 or £12 - but approaching £100 for a 12 cm hose just has me staggered. Donald
in the past..
Post #704145 30th Apr 2018 1:02pm
