![]() | Home > Puma (Tdci) > Should I clean engine ?? |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 ![]() ![]() |
Clean it . Spray electrical areas with WD40 and leave to dry .Nothing like mud etc left there to initiate corrosion and acting as a grinding paste to all moving parts.
Same as above WD40 jetwash get rid,
Iv had no problems ![]() leve it running NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY Last edited by fekete on 8th Feb 2009 1:25pm. Edited 1 time in total |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
i would steam clean it yes. Cheers
Do it with a warmed up engine so it dries out rapidly.
and go for a drive straight after. (good practice after cleaning any vehicle)
i have always steam cleaned or pressure washed engines either off or running tdi, tgv, td5 - tdci hasn't been used properly yet so is yet to be done. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 ![]() ![]() ![]() |
Thank you everyone for the advice. I was a bit worried about those electrical connecting plugs around the engine. I will buy some WD40 and spry it on the electrical connecting plugs etc. And then spray the engine with carefully with water.
Regards Anthony |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
WD40 - never leave home without it
![]() + New Defender 110 First Edition |
On special at Lidl next Monday ![]() |
Also excellent for removing oil off things and driveways ![]() |
If you dont have WD40 in SAFFA , use Q20 ,spray all connectors , pressure wash , and drive it dry
