Home > Maintenance & Modifications > Bilstein vs OME or vs any (except koni)
MK
Somebody had experienced those dampers and share an opinion? Puma 110" SW
Post #70139 8th May 2011 10:25am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I have the Bilstein..Great shocks Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #70170 8th May 2011 5:46pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Also have Bilstein, and very pleased with them. Nice, supple ride.
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #70211 8th May 2011 10:47pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Odd question, but why not Koni?
Post #70325 9th May 2011 10:10pm
MK
Because Koni are adjustable and no long travel AFAIK Puma 110" SW
Post #70345 10th May 2011 1:07am
BigMike
If you have long travel and drive offroad on anything causing big articulation you'll need dislocation cones.
I have OME, can't fault them. The ride is fabulous and they cope beautifully with harsh conditions.
Post #70383 10th May 2011 9:51am
MK
Oh yes I have them. But did you have bilsteins before? Puma 110" SW
Post #70385 10th May 2011 9:56am
BigMike
No I had terra firma big bore which are good fir heavy weight hauling but not so good for day to day driving
Post #70386 10th May 2011 9:58am
MK
So, In which way you find OME better than OE shocks? Puma 110" SW
Post #70389 10th May 2011 10:23am
BigMike
They're more progressive, smoother but also quicker in terms of return. They handle weight better than oe (I have iron man springs, B which are medium weight and the combination is excellent. The ome's really force the wheel down offroad and help maintain traction and they don't get hot on corrugation like oe do.
The springs give 1.5 inches of lift on the rear and 1 inch on the front but there is no problem with binding or prop angles. I did put cranked trailing arms on as with oe there was a gap at the top of the trailing arm front bush when not carrying heavy load. I've tried several setups on my current 90 and in previous ones and this one is the best by far. Depends on what you're doing with it though, my setup may not be right for you.
Post #70391 10th May 2011 10:38am
