Home > Puma (Tdci) > Convert heated seats to cooled ones
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi I am curious if anyone of you got around to converting a heated seat into a cooled one. I believe defender seats are using the same peltier principle to heat the seat like in any other car. Changing the polarity of the peltier device should turn it into a cooler. All this is possible or am I just letting my imagination run wild..? Has anyone of you thought about it? I live in the tropics so a heated seat is of no use. Thanks in advance for any suggestions.
Post #703143 25th Apr 2018 8:00pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I’m not an electrical magician but can safely say that it wont work ... however I will stand corrected if proven wrong ! Laughing
it may be better to look at the later G4 discovery seats as, if my memory serves me correctly, these were a special cool mesh that allowed your back to breath.
the other way is to put ice water into a hot water bottle and place it behind you back like a small cushion ...
just my thoughts !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #703163 25th Apr 2018 8:51pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I'm fairly sure they are just resistance heaters, having replaced a pad on mine recently. They have a wire snaking through the pad and sit between the foam of the seat and the leather/cloth cover.
Peltier elements appear to be rigid, and I'm not sure you could get any powerful enough and with good enough heat transfer to make a difference. I'm also happy to be corrected and interested to see if you could retro-fit any.
Cooled seats that I've had before have involved a cool air duct from the air conditioning system.
Post #703184 25th Apr 2018 9:39pm
zsd-puma
Agreed, Defenders just use conventional heater elements, they'll only heat up regardless of which way you run the polarity.
Post #703208 25th Apr 2018 10:39pm
discomog
I don't believe the Defender seats are heated by the peltier effect. I'm sure if they were many of our Antipodean members and dealers would have converted them to cooled seats. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #703221 26th Apr 2018 6:15am
Arsath
So does anyone know a good kit that could be used for cooling?
Post #703303 26th Apr 2018 2:15pm
discomog
http://www.aftermarketsystems.net/comfortzonecoolseats.html Defender 90XS SW
Morgan Plus 8
Post #703319 26th Apr 2018 3:16pm
gilarion
I don't know if they still do it but Exmoor used to do seat cover replacements using a fabric that keeps you cool in summer and warm in winter. Don't know if they still do it though, No harm in giving them a call and asking. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #703344 26th Apr 2018 5:44pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Re: Convert heated seats to cooled ones
The seat heaters are definitely not peltier elements...
You could run a liquid system, with a matrix of small bore pipes under the seat fabric, then run these to a cooling block with a pump, peltier module and associated heatsink and fan.. Similar to liquid cooling a computer cpu..
The cooler / fan / pump assembly could be mounted in a box attached to the cubby... And by reversing the polarity of the peltier elements, you keep heated seats in winter!!
Should be a simple enough project to get done in a weekend.. Very Happy Very Happy Very Happy ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #706082 8th May 2018 8:35pm
jst
Outlast IIRC
i have some mesh seats from Exmoor Trim to suit Defender which work really well. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #706098 8th May 2018 9:17pm
