![]() | Home > In Car Electronics > Spring-loaded carling switch? |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
How about a latching relay controlled by two momentary carling switches?
Press either switch once, 12v sent to relay, light on. Press either switch again, 12v sent to relay, light off. 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
That's exactly what I have planned for my 110 using one of these for the relay:
Click image to enlarge Ludicrously cheap from eBay: https://www.ebay.co.uk/itm/1-Channel-12V-L...1438.l2649 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| olivers Member Since: 19 Jan 2012 Location: Southern Scotland Posts: 115
Good idea... I wasn’t thinking to use a relay because they’re LED lights. But that should solve the problem nicely. Thanks!
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Or you could be extra fancy and make it wireless! Thats my plan for the rear lights.
If not could always run two feeds |
I think I’ll add a remote controlled switch into the circuit later, but nothing fancy... just waiting for ebay delivery from Hong Kong
Update: I got some of those latching relays from ebay, and just wired things up to test with two carling off-mom switches. Works a treat!
Excellent! When you install, don't forget to include a warning light on the dash.
I haven't played with my relay yet but I believe it will default to the 'off' state if the power is interrupted. If you wanted to be really cunning, you could power this relay via a changeover relay connected to the brake lights, so that when you brake it cuts the power. That way, you wouldn't risk driving around with the work light left on by accident. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
