![]() | Home > My Defender > An Anoraks Tdi Defender 90 |
It covers the opening in the bottom of the battery box where the bolt hooks in. Darren
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5320 ![]() ![]() |
I will have to see if I still have mine
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 ![]() ![]() ![]() |
Darren,
Where did you get the 'pocket' from. Manufactured it yourself or a bought item. Recently replaced my battery on my 300tdi and can't remember seeing this item. Cheers, Simon PS- loving your new Utility. ![]() |
I adapted an alloy project box, which was my very last purchase from Maplins
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ok, thanks for that. Went out and had a look underneath. There are two small covers over the slats, that the hooks go into (looking from underneath) so at least I know nothing has fallen off!!. Cheers, Simon
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 302 ![]() ![]() ![]() |
Ive got the same snorkel as yourself - mine is badly rusting on the top mushrow piece, is that just fixed on by the top bolts (highest up the windscreen)? |
The mushroom top is held on by a large jubilee clip or clamp to the top of the tube. The windscreen bolts secure the tube itself. Darren
I cant see any clips on mine where the mushroom bit is there is a very tight thick rubber band possibly a seal then only some plastic teeth like jubilee clip :/ and then just the bolts that bolt onto body near the windscreen.
The thing with the plastic teeth is the clamp
Thanks matey, I guess you just slide them outwards to remove them.
Thanks again and your thread is like a running Haynes Manual! I love all the tinkering bits, taking bits off respraying etc - in fact where did you get your paint tins from? Did you do the hinges etc just from rattle cans? |
Yeah, from memory they slide sideways to release.
The paint came from The Paint Man for the coach enamel and eBay for the rattle cans. Yes, the hinges were just done with rattle cans - rubbed down and etch primed before regular primer and top coats. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Mark0 Member Since: 12 Oct 2024 Location: Austin, TX Posts: 9 ![]() ![]() |
