Home > In Car Electronics > 1 or 2 DRL controller's
Wheel
Gent's.
I'm hoping someone can help regarding wiring up my DRL's.
I have 2 pairs of DRL's fitted (2 lights either side), each pair has a controller and I wondered if I need to use both or if I can get away using just one.
I was going to wire the outer's on one controller and the inners on the other so I at least have a pair should there be an issue and then got to wonder if I need both.
Has anyone any experience of this or similar please ??
Thanks,
Mark
Post #701961 20th Apr 2018 10:20am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
No reason that they can't run on one BUT you need to check the output current for the controller you use is up to the job of providing power for 4 sets of lights rather than two.
Figure out what power/current each DRL draws then check the specs on the controller. http://www.yorkshireoffroadclub.net/
Post #701963 20th Apr 2018 11:33am
mk1collector
I might be wrong but I thought you were only legally allowed to have one set of drl's on. Ray
My build thread
Post #701964 20th Apr 2018 11:46am
Wheel
Thanks Dave + Ray,
I'm going to go with my original idea to run two controllers, one on the inner and one on the outer set.
I like the look of the Urban twin set up which is where I got them + was basically copying that, as for the legalities I honestly don't know but there are plenty around with 4 and I haven't read anything on here regarding them so i'll give them a go and see
Mark
Post #701965 20th Apr 2018 12:48pm
davew
Not seen that mentioned in any of the legislation, as long as they don't dazzle other drivers there doesn't seem to be a limit on the number of DRLs, would be difficult to implement anyway as many DRL units often consist of multiple lights themselves. They have to have a control unit that either switches them off or dims them for use as side markers so perhaps if you dim them, rather than turn them off with the lights, they need to comply with sidelight positioning regulations too though ? http://www.yorkshireoffroadclub.net/
Post #701967 20th Apr 2018 1:01pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I stuck with using 1 controller for 2 lamps,
the outer ones are wired differently to the inner ones,
It seemed a sensible option to keep the pairs separate, with their own controller. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #701968 20th Apr 2018 1:10pm
mk1collector
I thought I saw it in one of Brendan's posts but wasn't certain Thumbs Up Ray
My build thread
Post #701986 20th Apr 2018 6:22pm
grafty99
I thought I'd seen that you weren't allowed 4. However the new Renault Alpine has 4 definitely separate DRLs Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #702052 20th Apr 2018 9:37pm
mk1collector
Brendan usually puts up links to the legislation so I guess it must have changed if new cars are coming out with more than two. Ray
My build thread
Post #702079 20th Apr 2018 10:17pm
grafty99
Yeah must have, I would say 4 separate lights on this?
1990 Vogue SE
Post #702096 20th Apr 2018 10:37pm
mk1collector
Looks like it to me. Ray
My build thread
Post #702097 20th Apr 2018 10:38pm
