Home > Puma (Tdci) > Wont start |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2266 |
check on the the battery terminals. Or lock and unluck 3 times. Puma 110" SW
8th May 2011 12:04pm |
SVX90 Member Since: 31 Aug 2009 Location: Dubai Posts: 38 |
Thanks for the reply, but unfortunately I already tried that |
8th May 2011 12:06pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
When you say it won't start, does that mean nothing at all or does the starter turn? Do you have any dash lights on? If you do, do they dim when you try to start? As the key is loose in the ignition have you turned it to the starter position and wiggled it too see if it gives a brief connection? If you have a nanocom isolate the immobilizer and try to start it. If not try the DKC code and see if it will start. Other options are to put a dc clamp meter on the starter and see if there is any amperage present when starting but agree with you that it is probably the ignition module/ immobiliser and you should call out LR assist or contact dealer.
If it is a faulty ignition there is a way to start the landy without the key once the immobilizer is isolated but not going too say on an open forum However it would show if it was the ignition module at fault It is a bit of a strip down job but if you have a nanocom evolution and want to try it pm me. HTH Brian. |
8th May 2011 12:52pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Try the other key and remote Mike
8th May 2011 7:43pm |
