![]() | Home > Td5 > Turbo wastegate |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 671 ![]() ![]() ![]() |
I'm not sure, if any lubricant survives the temperature of turbo. I was solving similar problem - first the wastegate was stuck open - no power, second in garage they tried to free it and used some grease, it was nice for a few km, then is started to stuck close - overboost, engine limp mode and no power. I have removed the wastegate actuator, and moved the westagate several time, to free it. I have also replaced the thin hose to the actuator with new hose clamps, and now it looks good for last week.
First I tried to free the wastegate with actuator connected, but it was not enough, and because of the spring in the actuator, I had no feeling for the wastegate free movement. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
I think the only long term solution is to replace it. SP4x4 on eBay sell them for roughly £30. As far as I’m aware they are the only suppliers along with Forge motorsport but it’s 3x the price. I couldn’t recommend either But if I had to choose it would be the forge part as it looks well made.
Wastegate is internal part of hot part of turbo, don't mix it with actuator. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Apologies for not reading the post properly ! I’ll shut up!But... I used innotec deblock oil on a Mates and it hasn’t seized since, roughly 8 months ago. I took the actuator off so I could feel the arm move on the wastegate without the resistance of the actuator.
