Home > Maintenance & Modifications > New Clarion Head Unit
Page 3 of 3 <123
That purple wire will need to be connected to the live + feed on the reverse light circuit the same as you did with the camera power.
To avoid cutting the standard reverse light feed, that is factory fitted any more than your current connection.
(Not sure how you done it.) but I'd tap off of the aftermarket feed you already installed for the camera.
So the HU purple reverse wire needs to be reverse 12v +
Camera 12v +
Camera chassis earth -
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701123 15th Apr 2018 9:05pm
dorgmal
again Steve I can not thank you enough for taking the time to sort me out you have the patience of a saint.. wish I could afford to take it to a garage and get them to sort it... but where is the fun in the..
soooo..
I will try to explain what I have done and see if I understand what I should do.
I have spliced in to the reversing light.. taking and + and - feed to power the revering camera
run a video lead from the camera to the HU to the camera
this all works fine if I select the camera whilst I am in reverse..
HOWEVER to get the camera to automatically
I NEED to do is run a cable from the purple wire on the ISO block back to the camera + feed...
so would that mean the camera would have two connections to the positive? one from the reversing light.. and one from the ISO connector...
Sad Banging Head
Post #701199 16th Apr 2018 7:04am
Not quite as the power source is the switched reverse 12v feed, the camera is powered via this.
Tapping into the feed on the camera just avoids making two connections on the reverse wire.
You could connect the purple to the reverse near the front, but obviously you’d damage the wire again and it’s a pig to get to.
Personally I’d run to the back, as I suggested tapping into the camera 12v that is triggered from the single live connection you made from the reverse light feed.
In a lot of instances it’s not advisable to ‘borrow’ current draw from and existing circuit as this. But in this case you will be okay due to the camera drawing very low current.
Think of the reverse light + as the switch, but an electrical one not a manual switch.
Basically your only problem is your HU has no way of telling the reverse is activated and the camera.
Some auto sense, others don’t but both work equally well. 👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701226 16th Apr 2018 9:56am
dorgmal
ohhh my brain... soooo..
all I need to do is..
1. unplug the (+) feed to the camera from the reversing light (leave the (-))
2. Run a wire from the HU iso purple wire to the camera +
or will that still not detect when its in reverse ahhh
I dont want to take up more of you time Steve... you have been great but I will just have to save up and get someone to do it for me Big Cry Big Cry Big Cry Big Cry
Big Cry
Post #701242 16th Apr 2018 11:54am
Leave your +/- camera to the reverse light in situ.
Extend the purple from the HU all the way to the camera + and tap into that.
That'll make your camera and HU see + every time reverse is selected, off when not.
The - won't need to be changed or tapped into at all. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701260 16th Apr 2018 1:54pm
dorgmal
right so one wire from the HU to the + of the camera rodddger that.... will give it a go... think I will owe you a beer!
Post #701263 16th Apr 2018 2:30pm
Page 3 of 3 <123
