Home > Wheels & Tyres > Biggest Tyre’s on boost alloys
Keswick90dan
Hi
What’s the biggest size tyres you can fit in standard boost wheels?
I want them to look wider
Many thanks
Dan
Post #701130 15th Apr 2018 9:17pm
In practical terms 285/75x16 is the largest tyre you can safely run on Boosts, although the Fun Police will probably pop up in a minute with dire predictions of doom.
A Boost rim is narrower than the minimum specified by most tyre manufacturers for this size, but there are many people who have run this combination without any problems for years. The Fun Police will usually at this point mention insurance and predict loss of cover.
You will find that you probably need 30mm spacers with this combination since, unless you only want to orbit small planets, you will find that the turning circle becomes tricky. Mention spacers however and the Fun Police have to lie down for a while in a Dark Place.
Provided however that you insurer is ok with it, you can run 285s on Boosts with 30mm spacers with no problems other than the dirt you'll get all over the sides.
(Edited for spelling)
Post #701164 15th Apr 2018 10:26pm
Screbble
Good concise answer Blackwolf.
Saves me re-searching! Thank you Thumbs Up
Surely the Fun Police will be tucked up tightly in bed in case they have an accident during the hours of darkness?
Post #701173 15th Apr 2018 10:50pm
that man
England 2012 Defender 90 Puma 2.2 HT Corris Grey
Hi Standard look Cool to me,, But I'mold Laughing
Post #701175 15th Apr 2018 10:50pm
Keswick90dan
Thanks black wolf 👍 do you reckon 265/75/16 would be the better option would i need spacers with them or not?
Thanks dan
Post #701177 15th Apr 2018 10:58pm
265/75x16 was a standard factory-fitted size for some vehicles and you should have no issues. This size should work OK without spacers, won't throw as much crud up the sides of the vehicle, and (being a factory-fitted size) should not cause any insurance issues. Even the Fun Police can sleep on!
Provided that this size satisfies your cosmetic requirement (and they look good, filling the arches nicely), it is a good and popular choice, with a wide range of different tyres available.
Post #701220 16th Apr 2018 9:30am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I went from 235 to 265 on the old TD5.
Found the loss of steering lock in car parks a bit limiting so added spacers... Then I discovered how much crud gets plastered over the sides when off roading!
Would I do it again, probably not, but 265 BFG AT on spacers did look good.
Post #701253 16th Apr 2018 1:14pm
grafty99
This made me spit out my tea Rolling with laughter Rolling with laughter
Very true!
I ran 265s with spacers and dirt defenders. Found that spatter up the sides was not too bad Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #701254 16th Apr 2018 1:22pm
What's wrong with 255/85. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701257 16th Apr 2018 1:48pm
^^ Nothing, it's a great size although the choice of tyres is limited.
However the OP initially asked "what's the biggest size" and 285/75 is bigger than 255/85, then asked "can 265/75 be fitted", to which the answer is "yes".
Thumbs Up
Post #701265 16th Apr 2018 2:34pm
diduan
Bulgaria
I had 255/85 MTs on my boosts for 2 years, but a MT tyre is not suitable for my driving any more. I wanted to replace it with a 33" tyre, so I went to 285/75. I was surprised that the 285/75 is only 270mm wide! Mounted!
Cheers! Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #701279 16th Apr 2018 4:45pm
Is there any speedo issues with 285/75's? I'm quite happy with my 255/85's. Thumbs Up Mr. Green ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701294 16th Apr 2018 5:52pm
camelman
255s are actually a tad taller than 285s so will be having more of an effect on your speedo than 285s.
when I was running 285s I measured the speedo against the GPS and it was almost bang on accurate.
Post #701295 16th Apr 2018 5:54pm
Same with mine so there must be a very very small difference there, in fact it’s more accurate than the 235’s I had were which underread about 1 - 2mph.
I’m sure Blackwolf will back me up on this one, as this was a concern I had originally but they are perfect.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #701302 16th Apr 2018 6:22pm
diduan
Bulgaria
285/75 -> 100km on speedo = 102km GPS -> 2% difference for distance
The difference in speed is not noticeable. Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #701308 16th Apr 2018 6:41pm
