Home > Maintenance & Modifications > Bilstein b6
Page 3 of 3 <123
richg
United Kingdom 2007 Defender 110 Puma 2.4 XS DCPU Chawton White
I changed mine to alive springs and bilstein b6 shocks in my own garage. Used axle stands and standard tools, you can do one wheel at a time (you don't need to be a mechanic, just take your time)
Post #701025 15th Apr 2018 3:50pm
Indeed ^^^^ I done the same but standard set up instead.
Just be careful, soak any fixings in penetrating fluid overnight beforehand.
Ideal time to change spring seats and or add isolators too.
No spring compressors ever needed. πŸ‘πŸ» ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #701031 15th Apr 2018 4:12pm
Imax
This is very interesting reading as i am keen to do the suspension on my 110 Puma Hard Top.
I have been looking at the Twisted Progressive set up which they advertise for Β£2274. Not sure if this is a fitted price. Also had a look at the Alive site earlier and the cost seems a lot lower for the complete set of springs, dampers, steering damper and ARB.
Is the Twisted set up worth the extra?? I need to confirm if the Β£2274 includes fitting... I hope not!!!
I will need to get a garage to fit and will need to carefully consider whether to just go with the B6 Bilstein dampers and upgraded ARB. I did also phone Devon 4x4 and they recommended Old Man Emu dampers...
Sorry lots of questions...
Post #701085 15th Apr 2018 7:43pm
richg
I don't know for sure, but I am told that the twisted kit is exactly the same (although having said that the springs are different brand, but essentially the same compression etc).
It only takes a few hours to swap everything over (maybe 3-4), so I guess the alive or flatdog or devon kit is very good value.
There is a set of bilstein shocks available on here for sale, they are exactly the same as the alive ones, but the previous owner paid nearly 3 times the amount (essentially for the twisted badge)
Post #701100 15th Apr 2018 8:18pm
richg
Post #701101 15th Apr 2018 8:19pm
Only pain doing DIY I found was the damper top mounts.
Anyone got any tips for torquing them up? ____\We|Will|Win/___
Post #701109 15th Apr 2018 8:38pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
James I have genuine Land Rover bushes which I found to my liking .
Post #701125 15th Apr 2018 9:07pm
pesto_trader
Norway 2005 Defender 90 Td5 SW Tonga Green
Ok, basically the great setup is standard springs with Bilstein b6 right? How often does people change springs? They seem to last a long time. I dont do offroad too much. Would it be sensible to change springs after 60000 miles? Or is that almost stupid?
Post #701238 16th Apr 2018 11:04am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
The OEM coil springs will have been manufactured with at least a 100,000 mile life expectancy. Obviously failure of a coil spring is quite annoying depending how far from civilisation you are at the time. I'm probably going to run till one fails then replace all unless I start doing more expedition type stuff in which case I will replace before I start (at around 90,000 miles now) 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #701241 16th Apr 2018 11:38am
Page 3 of 3 <123
