![]() | Home > Tdi > Transfer case output flange oil seal |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
There is a breather, a black pipe with a banjo fitting onto the t-box.
It could also be wear on the sealing surface of the flange, a Britpart or other aftermarket flange manufactured out-of-round, worn bearings resulting in radial movement of the shaft, or a bent shaft. |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 ![]() ![]() |
Thanks,
Are the breathers prone to blocking? Roy 300tdi 90 1996. |
Axle breathers yes, but I've not heard of the t-box breather getting blocked before.
