![]() | Home > For Sale & Wanted > [Sold] 23k mile standard diff (sold) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
2011 diff centre removed and chemically cleaned by Ashcrofts a standard 23k front diff centre, this has never been wheel spun and comes off a pampered land rover no noticeable wear or issues
£20 prefer collected, I have a pair of new timken bearings that any purchaser can have for an additional £15 I will make a forum donation if sold on here prefer cash on collection I am near NEC but could post at cost in Ashcroft box ![]() Click image to enlarge ![]() Click image to enlarge DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 18th Apr 2018 7:35pm. Edited 3 times in total |
Hi,
can I ask a daft question. is it a 2 or 4 pin? I thinks it 2 but if its 4 then yes please. ![]() |
standard 2 pin (really 1) DEFENDER 90 TDCI XS,
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17881 ![]() ![]() ![]() |
Actually the diff has no "pinions" at all, it has two differential gears, two side gears, and one cross pin. All the gears are bevel gears.
The terms "two pin", and "four pin" as used in the context of Landrover diffs are misleading, inaccurate, and technically incorrect, but enormously widespread thanks largely to internet and its amazing ability to turn myth into fact! Better terms would "two gear" and "four gear", or "single (cross-)pin" and "two (cross-)pin" (even though a four cross-pin diff generally has one cruciform pin). Regrettably it is highly likely though that the accepted misuse will ever be changed now. Another example of this internet-driven butchery of technical language is the term "hawse fairlead", a non-existant and nonsensical alternative for the correct "plain fairlead". All the term "hawse fairlead" does is indicate that the user has no idea of the definition of the word "hawse"! Again it is, sadly, probably too late to do anything about this. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
This is turning out to be a really interesting thread, and hopefully also acting as few free bumps
![]() I'm pleased Blackwolf has raised this point as over recent years I was convinced that my long-distant engineering memory was playing up more regularly. I too thought these were bevel gears, and that a pinion had 'square' teeth - albeit a pinion is the smaller of two meshing gears, with the larger being the aptly named 'gear.' In any case, I fear you are correct Blackwolf, as not only are many basic engineering facts and nomenclature becoming lost over time, they are also distorted and in some cases completely 're-engineered' due to the power of the internet (or those uploading!). I won't mention bolts and set screws ![]() Back to the thread, I think it's a bargain and hope it sells quickly ![]() I do wonder if this would fit a TD5 90.... ![]() |
PS LR90XS2011
I've sent you a PM! |
provisionally sold (if anyone else wants one see my other posts) DEFENDER 90 TDCI XS,
Payment sent
![]() Thanks for sorting ![]() |
Sold DEFENDER 90 TDCI XS,
All arrived safe and sound today Rob.
Thank you very much for arranging the postage etc. I am very grateful. ![]() I may get in touch with you before Christmas to help with my present wrapping as your packaging was a work of art! ![]() ![]() Thanks Rob, Will |
£5 donation made to this great forum from sale
good luck with your diff rebuild DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
